SurfaceMeshesToPlanes does not see opened doors
pstueven
Hey,
I am having trouble with SurfaceMeshesToPlanes as it can't seem to see the doors in my room. Did anyone else experience this an found a solution? I would really like to see into the next room when having materials attached to the SurfacePlanes.
Thanks in advance
@pstueven
edit: I am Talking about opened doors. So basically holes in the wall.
I don't think that the SurfaceMeshesToPlanes script has that functionality available. I don't think it can determine the difference between a wall and a door. The types it can distinguish are: Walls, Floors, Ceilings, Tables, and Unknown.
*Where unknown is typically a flat surface but, has a shape other than a rectangle. Usually things like round tables fall under the unknown plane type.
AR Developer
Hi @dbarrett ,
thanks for your answer. I think the Unknown does not even need to be a flat surface but anything else than the other types.
Just to point out my problem: I am not talking about a closed door. It is basically a hole in the wall is being recognized as part of the wall surface. If I visualize the spatial mapping mesh, I can see that it is not scanned as part of the wall(). But the SurfaceMeshesToPlanes ignores that hole.
