Display computer screen in my hololens
gomes
Hello. Maybe what I'm going to ask is quite strange, but I need to do it for my project and I don't know where to start. I'd be very grateful if someone could tell me how to do it.
I need to stream my computer screen and display it in a window in the hololens.
I work with Unity.
Thank you in advance
That is the main purpose I had when I bought the HoloLens. I use remote desktop which does the job for office work but forget anything that requires fps like games. Been searching everywhere for an app like splashtop or trinus VR but never found anything . anyone ??
The best work around I have figured out is to use an Xbox One game system to stream from. You can hook up an hdmi input for passthrough of another system (pc, Ps4, Blu Ray players, etc.). I ended up buying two xbox systems for my two homes and am thinking of buying one for my office just so I can have the ability to access another system.
I have also contacted Splashtop to suggest that they make a hololens compatible app. The hololens 2 will be out soon (hopefully). And from what I have experienced AR will not be going away anytime soon. Maybe Splashtop will jump on this opportunity. If you need additional info on my setup to stream any device with low latency reply to this message.
Why don't you use Remote Desktop? Or do you need the computer screen to remain interactive?
