Samsung HMD Odyssey Black screen
Laptop GS72-Stealth-Pro-4K-6th-Gen-GTX-970M
CPU- Intel® Core™ i7-6700HQ
CHIPSET Intel® HM170
GPU GeForce® GTX 970M
BLUETOOTH 4.1
USB USB 3.1, USB 3.0
VIDEO PORT HDMI 1.4, mDP
I have all the windows update and the Mixed reality install fine without issues.
After the completion of the initial setup everything pass without issues.
Then start the app and for less than 1 sec the screen on the Samsung HMD work fine. Then goes black and only the cursors are present in the screen.
Any help?
Hi
Please check The screen inside of my HMD is black
If it still does not work please contact me.
Akira_Chen, I have the same issue with my Odyssey HMD I've bought couple of days ago. I have read "The screen inside of my HMD is black" section, but this not helps me to fix the issue.
