Cannot Run HoloLens Emulator (Hologram 101E App)
First of all, the HoloLens Academy classes are fantastic. I started following the course from 101E. I didn't have any major problems until I tried to run the app from Visual Studio. (The rebuild works with no errors.) If try to run the app, the emulator fails with the following error:
"The connection to the virtual machine is lost. The virtual machine might be disabled by another application. The emulator must close."
Has anybody encounter a similar problem? Any solution/workaround? (FYI, I have no problem running Win10 phone emulators on this machine.)
~Harry+
ahillier mod
Hi @harryplus,
I'm glad that you are finding the academies useful!
For the emulator issue, type 'Hyper-V Manager' in your Cortana search box to verify that the emulator shows up under the Virtual Machines section. You should be able to right-click on the emulator entry and select 'Connect'. If you happen to have multiple entries, you can remove them. If you still can't get it to work, I would suggest removing all entries, uninstalling the emulator, and then re-installing again. You might also want to reboot your machine to make sure everything is started correctly. When you first launch the emulator, a new entry should appear in the Hyper-V Manager.
I hope this helps,
~Angela5
Hi @harryplus,
I hope this helps,
~Angela
Hi Angela,
Thanks for the reply, and for the helpful suggestions.
(1) I didn't have anything unusual on my Hyper-V Manager. No duplicate entries, etc. The interesting thing is that I was able to start (and connect to) the HoloLens Emu virtual machine with no problem from Hyper-V Manager.
(2) But, every time I try to run the emulator from Visual Studio, always the same error. I tried removing entries from Hyper-V Manager, and uninstalling/reinstalling the emulator, etc., but nothing really worked.
(3) Then, I found an interesting workaround. I started the emulator VM from Hyper-V manager first, and then tried running the app from Visual Studio. This actually started the app in the emulator with no issues.
I now successfully finished 101E, and I'm moving on to 210.
~Harry+
Hello harryplus and ahillier,
Looking for assistance as well. I have a vmware workstation running win10, studio and hyperV, etc
when i open the project and debug the app, i see the VM being created in hyperV, but then i get an error popup in studio stating "Canno assign the specified number of processers for virtual machine...". when i close the popup, the VM in hyperV then disappears.
I have tested manually creating a dummy VM in HyperV just to make sure it works, and it does.
Any help will be much appreciated.
@James,
Have you seen this thread? https://forums.hololens.com/discussion/414/couldnt-change-the-processor-of-the-virtual-machine
The discussion there might be relevant to the issue you are having.
~Harry+
@harryplus ,
Yes, I followed that thread. There was no positive outcome for that person, or myself when i tried following what i could, since i am not using parallels.
I even followed this nicely documented thread: windowscomments.com/?p=1491
This one worked for me. Thanks Harry
