App follow camera smoothly
Hello everybody,,
I am just starting to build apps in hololens using unity with toolkit.
My window contains a menu and I put the menu under MixedRealityCamera ( to make the app moves with user' head ) but it is not smooth, can I put my app something like Hololens start window. It is possible?
Thanks all.
I think what you are looking for is the Tagalong script from the MRTK. There are a few variations to this script but it smoother than just attaching it as a child to the camera. This also makes it so that you do not have to have it as a child either.
AR Developer
Check out the Tagalong scripts. SimpleTagalong, Tagalong, and SphereTagalong. Though they are broken in Unity 2017.3 so use Unity 2017.2 or earlier.
That way you do not need to place them under the camera object. They won't be as annoying and they will smoothly move back into your frame of view.
