QR reader and position
Hi ,
I am student will be working on a project where QR/barcode scanning is needed and other special virtual objects need to be created like virtual humans . I will hang some QR codes for special human conversation and other usage .
I am really interested in using Hololens in this project but have some questions before I decide to go a head . My plan as I explained is to create some virtual objects such as specific 2D/3D shapes ( QR...etc ) or two virtual human conversations . In my project , I need to locate this virtual objects so my questions are :
Is it possible to create a specific virtual objects with Hololens ? in other words. Can hololen be programmed to create a specific objects like QR ( Quick response ) code , virtual ....etc ?
IF yes. Can I locate this object ( get x,y,z 2D /3D) and is the location is accurate with Holones or there wil be l some errors and how much percentage will be the error in your experience ?
I saw some tutorials on UWP, QR Code Scanning with ZXing and HoloLens ( not sure if they are able to get the location of the QR ) so the Holons Sdk can not craete these QR alone . it must be used with ZXing.
https://mtaulty.com/2016/12/28/windows-10-uwp-qr-code-scanning-with-zxing-and-hololens/
I am totally new to Hololens.
Regards,
mart1243 ✭
elahemer,
I am working on a somewhat similar project with the HoloLens! Is your question regarding "getting the location of the QR" in terms of if a user can look at a QR code and then it will jump to the designated web link, or whether a developer can embed an image of a QR code in a space?1 -
elahemer ✭
mart1243
thanks for your replay and I am sorry I just get back . I really was sick and recover and back to school now.
I am happy that you work in same project .
I am new to Hololens but what I am trying to is to create qr object and get how far this from the hololens . So Create this qr and then get its location with respect to Hololens. so developer can embed an image of a QR code in a space and get its location?
Regards0
elahemer,
mart1243
Regards
so the goal is to have both real and virtual qr and their locations
mart1243
can you answer my question please ?
