Issues with Graphics Driver
Ramu
So I'm not sure if this is where I should be asking this question but I'm going to try anyway.
I'm planning on purchasing the hp mixed reality headset soon and so I ran the PC check first to make sure everything would go smoothly. My issue is that even though I have a WDDM 2.2 driver it still says the driver isn't compatible. Does anyone know what I'm doing wrong?
Hi, please refer to this post : https://forums.hololens.com/discussion/8267/mixed-reality-minimum-requirements-and-wddm-2-2
And check your GPU is compatible or not.
