Mixed Reality units needed for QA
I am a QA Manager in one of the QA houses and we were looking into the possibility to test Mixed Reality applications. I have reviewed materials available online but still remain with some questions:
- what type of hardware is needed to be able to perform QA on the app that is still being developed? Is there a way to start such app on the retail version of Mixed Reality Headset or will we need Development Edition of Immersive headset
- Is it possible to connect the retail unit to Windows Device Portal by enabling the development mode (similarly to Xbox One)?
Adam
First question:
Depends on the processing demands of the software. Minimum requirements of the mixed reality headsets can be found here: https://docs.microsoft.com/en-us/windows/mixed-reality/enthusiast-guide/windows-mixed-reality-minimum-pc-hardware-compatibility-guidelines
Second question:
Yes. Specifics go into here: https://docs.microsoft.com/en-us/windows/iot-core/manage-your-device/deviceportal
The generalized answer, there is no difference between the Developer editions and the Consumer editions of the Immersive MR Headsets, aside from some minor cosmetic and fit things with a couple of them (Acer changes the headband adjustment, added padding).
