How to live stream video from hololens to pc?
Hello,
I am trying to stream live video including holograms to a UWP App which runs on a PC. I do not want to use the REST API which is supported by the hololens natively since it has a 2 seconds delay. (I would use it for testing anyways, but I cant figure out how to receive the stream via http://172.22.111.82/api/holographic/stream/live_high.mp4?holo=true&pv=true&mic=false&loopback?holo=true&pv=true&mic=false&loopback=true , MediaElement.Source does not work for me)
Is there an efficient way for my problem. I am using Unity for my holographic app.
Thank you very much in advance
Optionsjames_ashley ✭✭✭✭
Nope. sorry. I misread your question the first time somehow. Do-over.
Try this sample code: https://github.com/Microsoft/HoloLensCompanionKit/tree/master/MixedRemoteViewCompositor/Samples/LowLatencyMRC
It requires adding an extra component to your hololens app, but the performance is really good.
If you need to stream apps you don't own, though, I don't think there is a way around using the REST APIs.
www.imaginativeuniversal.com5
The best thing is to switch to a UWP app if you can. To get over the delay, you can use the low latency MRC. I was never able to get this working in a WPF app, either.
You mean use uwp/directx rather than unity?
Thank you very much. I think this is exactly what I need. But I cant find the Build directory in the repository, mentioned in the guide. There should be a build directory containing the file MixedRemoteViewCompositor.unitypackage
How do I generate this?
Look inside the sample unity project, TestScene. They may have moved things around but you should be able to find it in there.
the binary files are no longer included. WSA project wont load with vs2017. Installed vs2015 and it says the project is incompatible with this version of visual studio.
Are there any up-to-date instructions on VS version/building this?
Try to get it from here: https://isgb.otago.ac.nz/infosci/jack.wynne/Scott/tree/master
Unfortunately I didn't get it to work as well.
LowLatencyMRC includes a Readme with invalid instructions, referring to a .UnityProject file that does not exist. Any revision to the 'Accepted Answer' would be appreciated.
Has anyone found a way to install/start the LowLatencyMRC sample ?
