Projecting a visible Ray from the motion controllers similar to the default cliffhouse space?
Hi everyone I am working on incorporating the visible controller models into our project and am using the HoloToolkit in unity to do it. I've managed to omit some unnecessary libraries and Hololens features ( such as spatial mapping) to get our build to actually export from unity and everyting runs well in the editor.
For some reason whenever I tweak the LeftHandInputControl and RightHandInputControl prefabs and enable them to display the raycast nothing shows up . When I press a button a cursor dot shows up where I believe a ray would end , unfortunately though the actual line being cast from the controller to this endpoint isn't visible and I'm not quite sure if it's user error on my end or if I'm just not grasping how the holotoolkit works in regards to the motion controllers. Here is an example pic of my layout currently in editor, you can see the model and the cursor / endpoint for the raycast hovering just at the head of the seat but as shown no Connecting Ray between the controller and the endpoint . Does anyone have any advice or resources on how to accomplish something like the default raycasts you can see in the main mixed reality lobby ? Thank you very much !
OptionsEvoxVR ✭
@mark_grossnickle thank you So much your code worked , I had to make a few modifications on my end ( like the big ugly If else statements for controller handedness because I was getting an error on an unassigned controller reference declaring it the way you did ) but otherwise the Rays are working great.
For anyone else looking to do something similar I updated the UpdateControllerState() function in the MotionControllerVisualizer.cs class
I declared the following variables at the top of the class and Created two LineRenderer Game Objects that correspond to the right and left hand rays and currently exist in the scene .
//*** Line objects public LineRenderer LeftPointerLine ; public LineRenderer RightPointerLine; //*** Line Distance public float lineDistance = 100f; public bool displayPointerRay; private void UpdateControllerState() { #if UNITY_WSA && UNITY_2017_2_OR_NEWER foreach (var sourceState in InteractionManager.GetCurrentReading()) { LineRenderer line; MotionControllerInfo currentController; if (sourceState.source.kind == InteractionSourceKind.Controller && controllerDictionary.TryGetValue(GenerateKey(sourceState.source), out currentController)) { if (AnimateControllerModel) { currentController.AnimateSelect(sourceState.selectPressedAmount); if (sourceState.source.supportsGrasp) { currentController.AnimateGrasp(sourceState.grasped); } if (sourceState.source.supportsMenu) { currentController.AnimateMenu(sourceState.menuPressed); } if (sourceState.source.supportsThumbstick) { currentController.AnimateThumbstick(sourceState.thumbstickPressed, sourceState.thumbstickPosition); } if (sourceState.source.supportsTouchpad) { currentController.AnimateTouchpad(sourceState.touchpadPressed, sourceState.touchpadTouched, sourceState.touchpadPosition); } } Vector3 newPosition; if (sourceState.sourcePose.TryGetPosition(out newPosition, InteractionSourceNode.Grip) && ValidPosition(newPosition)) { currentController.ControllerParent.transform.localPosition = newPosition; //*** Custom Ray logic //InteractionInputSource currentController; //line = currentController == InteractionSourceHandedness.Left ? LeftPointerLine : RightPointerLine; if(currentController.Handedness == InteractionSourceHandedness.Left){ Debug.LogWarning("Left Controller Active, creating Ray !!!!"); line = LeftPointerLine; if(displayPointerRay && line != null){ //*** Custom Ray Logic if(!line.enabled) line.enabled = true; Vector3[] linePositions = new Vector3[2]; linePositions[0] = currentController.ControllerParent.transform.position; // // Original writers cursore snippet var inputSourcePointer ; [= TQCursorManager.instance.pointer as InputSourcePointer] Quaternion pointerRotation; if(sourceState.sourcePose.TryGetRotation(out pointerRotation , InteractionSourceNode.Pointer) && ValidRotation(pointerRotation)) { linePositions[1] = sourceState.headPose.position + (pointerRotation * Vector3.forward * lineDistance); } line.SetPositions(linePositions); }else{ if(line != null && line.enabled) line.enabled = false; } } if(currentController.Handedness == InteractionSourceHandedness.Right){ Debug.LogWarning("Right Controller Active, creating Ray !!!!"); line = RightPointerLine; if(displayPointerRay && line != null){ //*** JJ Custom Ray Logic if(!line.enabled) line.enabled = true; Vector3[] linePositions = new Vector3[2]; linePositions[0] = currentController.ControllerParent.transform.position; // // Original writers cursore snippet var inputSourcePointer ; [= TQCursorManager.instance.pointer as InputSourcePointer] Quaternion pointerRotation; if(sourceState.sourcePose.TryGetRotation(out pointerRotation , InteractionSourceNode.Pointer) && ValidRotation(pointerRotation)) { linePositions[1] = sourceState.headPose.position + (pointerRotation * Vector3.forward * lineDistance); } line.SetPositions(linePositions); }else{ if(line != null && line.enabled) line.enabled = false; } } //*** end custom Ray logic } Quaternion newRotation; if (sourceState.sourcePose.TryGetRotation(out newRotation, InteractionSourceNode.Grip) && ValidRotation(newRotation)) { currentController.ControllerParent.transform.localRotation = newRotation; } //DebugInteractionSourceState source; //source = (DebugInteractionSourceState) sourceState; /*Ray newRay; if (sourceState.SourcePose.TryGetPointerRay(out newRay)) { if (ShowPointingRay && Physics.Raycast(newRay)) { Debug.Log ("!!!!!!!!DRAWING RAY!!!!!!!!!!"); // TODO shanama: get pretty ray here, maybe an "active" ray and an "inactive" ray for when buttons are pressed Debug.DrawRay(newRay.origin, newRay.direction, Color.cyan); DrawLine (newRay.origin, newRay.direction, Color.white); } }*/ } } #endif }
Here's a picture of my end result sorry it's not better taking a screenshot in editor while holding the controller and headset at an angle to view everything was tricky :
1
How are you tweaking the prefab? I may not be on the latest toolkit so perhaps they added something but last I checked there was no option for adding a raycast line.
We ended up adding our own. We added a LineRenderer for each hand (LeftPointerLine and RightPointerLine).
Within UpdateControllerState's foreach loop of states:
line = currentController.Handedness == InteractionSourceHandedness.Left ? LeftPointerLine : RightPointerLine;
Then when it goes to set the controller's position update the lines here. We use a custom CursorManager so you will need to change that to your cursor's position (commented line below):
if (DisplayPointerRay && line != null)
Awesome Mark I will replicate this in my project and report back , I appreciate the help !
FYI, this is also coming in the Mixed Reality Toolkit soonish
@mark_grossnickle In response to how I am modifying the prefabs I'm just enabling and disabling the various booleans for showing rays , and rendering lines. They work for the debug rays but no Rays actually visible in the game view.
Debug.Ray is editor only I believe:
https://docs.unity3d.com/ScriptReference/Debug.DrawRay.html
