Disable or Remove a BoundingBox using MR Design Labs
Hey,
I'm using the MR Design Labs in my Unity project and I can't remove or disable a BoundingBox that was assigned to an object.
I'm trying to destroy these components from a voice command.
public void ApplyPosition() { Debug.LogWarning("Apply Position called"); Destroy(boundingBoxGameObject.GetComponent<BoundingBoxTarget>()); Destroy(boundingBoxGameObject.GetComponent<CompoundButton>()); }
or disabled it.
public void ApplyPosition() { Debug.LogWarning("Apply Position called"); boundingBoxGameObject.GetComponent<BoundingBoxTarget>().enabled = false; boundingBoxGameObject.GetComponent<CompoundButton>().enabled = false; }
boundingBoxGameObject is defined, I can navigate through methods and variables well, but, no way to disabled boundingbox.
The idea is, I need to apply user definitions and remove bounding box behaviour after that, saving rotation data. How is the way to do that?
Thanks.
james_ashley ✭✭✭✭
I think this might do it for you: ManipulationManager.Instance.ActiveBoundingBox.Target = null;
www.imaginativeuniversal.com6
Kinda crazy, but I'd forgotten about this and was trying to find a way to get rid of all the bounding boxes, so I googled it and ended up in another thread that pointed to this thread. And it works.
Additionally I wanted to get rid of the app bar, which I'm doing by just putting it very far away:
ManipulationManager.Instance.ActiveAppBar.transform.position = new Vector3(0, 100);
@james_ashley @Lazarofl
Please check out Dev_Working_Branch of MRTK. We ported Bounding Box and App Bar to MRTK:
https://github.com/Microsoft/MixedRealityToolkit-Unity/blob/Dev_Working_Branch/Assets/MixedRealityToolkit-Examples/UX/Readme/README_BoundingBoxGizmoExample.md
