AirTap to take photo of view from hololens
Where would you start to create a basic app that when you air tap it takes a photo and stores it on device. The app will do more then that but that is where I need to start.
Is there sample source code for this out there?
james_ashley ✭✭✭✭
You can pretty much just copy and paste this Unity code for the locatable camera.
www.imaginativeuniversal.com5
@JD_Holo_Dev ,
The Unity code ? does it work with air tap gesture?
@Xyy You just need to inherit from the
IInputClickHandler
from the MRTK and put it under theOnInputClicked
methodAR Developer
I have writed code just like this,however it doesn't work on hololens.
Can you give me some help? Thank you very much!
@Xyy You need to add a listener to your object this is attached to. There is a script already written that does this called
SetGlobalListener
. You would use this if you just want to air tap anywhere in the scene to take a photo otherwise, you need to air tap on the object that has your script attached to it.AR Developer
