Hololens server communication('MessageWebSocket' does not contain a definition for 'MessageRecieved'
Hey All
After countless failed attempts and rigorous search, I'm still stuck with which I assume a very straightforward issue.
I'm building a socket communication channel between a Hololens(client) and a python server and I am successfully able to make a connection between them using a MessageWebsocket too.
Now When I use "MessageReceived"( https://docs.microsoft.com/en-us/windows/uwp/networking/websockets )event to handle the message from the server, Unity while building simply gives me a message that MessageWebsocket doesn't contain MessageRecieved event :
"error CS1061: 'MessageWebSocket' does not contain a definition for 'MessageRecieved' and no extension method 'MessageRecieved' accepting a first argument of type 'MessageWebSocket' could be found (are you missing a using directive or an assembly reference?)"
The error clearly states that its missing MessageRecieved extension but "Windows.Networking.Sockets" actually does contain the event extension.
I have even tried reimporting all the libraries still no result.
Any hints and help are appreciated.
Hava you solved this problem? I also meet these problems, and don't know how to do next…
