MR toolkit Motion controllers not rendering in app on Initial launch ?
Hello everyone I am using the latest version of the Mixed reality toolkit (2017.2.1.3) in unity 2017.4.0f1 . In my current setup the Motion Controllers are attached to a static Camera prefab which is placed in the very first scene .
Whenever I make an app package and launch it for some reason upon initial launch the controller models are not rendering in the environment , however if I press the Microsoft button on the motion Controllers and exit the app then re-enter by selecting the already open app the motion controllers render perfectly fine .
I tried running the example motion controller scene and in editor it runs perfectly fine but when I launch that as the initial scene in my created .appx package the are white cuboids appearing in the same space the motion controllers should be rendering.
Ultimately my question is has anyone else encountered this issue with the tracking / rendering of the controller models on the initial launch and can anyone offer a solution ?
Please try to build with 2017.2 version Unity3D. 2017.4.0f1 is still a test version so that you may encounter problems like that.(I cannot even build 2017.3 version but everything is fine in 2017.2)
