hololens trough polycarbonate visor
in Projects
hi there, i'm writing as i'm developing an interesting product with hololens to be placed behind a visor in manufactoring enviroment.
i noticed that when i put the visor on, in my spece location holograms tend to slide a little bit... i suppose is because the IR and depth sensor have distorced information on the real time basis.
the location is previously scanned and after the visor in on, seems its not understanding the placement.
in your opinion... what if i cover the IR emitters? could it work? or the ir emitters and the depth sensor too...
what do you think?
Dave.
No ideas? Can someone help me?
Not exactly the same but if you haven't seen it you might like to look at this - http://digitalreality.guru/2016/12/project-using-the-microsoft-hololens-outdoors-with-a-visor/
The author also did a follow-up where they cut holes for the sensors, reporting that it worked better.
