What's wrong with my code? (Airtap to play AudioSource MixedRealityToolkit)
Hi, I'm using Unity 2017 and what I believe is close to the most recent version of MRTK. I'm trying to get it to where i tap on an object and it plays an audio file. I have a similar problem getting an audio file to play with the Speech Input Source and Handler so i believe my problem is with the audio code. Any ideas? Here's my code:
`using HoloToolkit.Unity.InputModule;
using System.Collections;
using UnityEngine;
public class AirTap_PlayAudio : MonoBehaviour {
// Use this for initialization public AudioSource audioSource; void Start () { if (audioSource == null) { // if AudioSource is missing Debug.LogWarning ("AudioSource component missing from this gameobject. Adding one."); // let's just add the AudioSource component dynamically audioSource = gameObject.AddComponent<AudioSource> (); } } #region IInputClickHandler public void OnInputClicked(InputClickedEventData eventData) { audioSource.Play(); } #endregion IInputClickHandler // Update is called once per frame void Update () { }
Does it play in Unity when you play it? Anyerrors, warning or info in output log in Unity? Does your audio source has a source file? Volume not muted?
