WebView in Unity and HoloLens
kamendkamend
edited November 2016 in Questions And Answers
I am looking for a WebView solution inside my HoloLens app, we need to display a map from a custom web based solution in the 3D view along side other uGUI dialogs..
Any ideas or a ready Asset Store solution?
    Hi, I am asking myself the same question. I want to display a webapp as UI inside Hololens 3D view but none of the webview solutions I found on the asset store is working with UWP.
    Unfortunately there is no easy answer for this at the moment. The closest one would be the Awesomium plugin but that is not free and does not currently work under UWP. You can read more about that here. The easiest solution is to pop up the system browser, but that has the user leave your experience which is not ideal.
    Our Holographic world is here
    Do you have any updates on this? How to show a webView inside a holographic app session?
    Same problem.
