Headset not connected (even though it is...)
The headset is plugged into a 3.0 USB port on the back of my computer. The HDMI cable is plugged into my graphics card. The Windows Mixed Reality portal randomly started and told me the headset is working, I got excited and play the little tutorial mini game with the gems, then suddenly it got disconnected and no matter what I do I can't fix it. It was working before, I've done the setup multiple times, but the headset just randomly stops. Is there some requirement for the headset to count as connected?
The USB is snug in the slot, I've tried wiggling it slightly.
I've read the troubleshooting guide.
I can't find any help online.
There are 2 3.0 ports on my PC on the back and 2 in the front, but of course the cable for the HDMI and the USB are too short to reach the GPU while the USB is in the front. Does anyone have any suggestions to make this work?
Have you check your USB driver? HMDs work best with USB controllers running the Microsoft USB driver stack.
You can try uninstall your PC's current USB driver, and then reinstall a Microsoft driver:
Also, you may refer to this section in Troubleshooting Guide to update/install the latest driver for your headset.
I am having the same problem. The Mixed Reality Portal says I am good to go, but says connect your headset, even though my HMD is connected and I can see the desktop from it. I have followed the same instructions on incompatible drivers, still doesn't work.
The HDMI is connected to an Nvidia 1080 and also tried a Vega 64 and USB 3.0 to HDMI 4k dongle, both have the same problem.
USB is connected to onboard USB 3.0.
fixed this by going into Mixed Reality Portal -> See more -> Settings -> Headset display -> Experience options -> Change -> [set to highest refresh rate]
I don't know why this worked but it did for me so try it at least. ¯_(ツ)_/¯
