Building a Unity App using httpclient and ignoring certificates
Hey everyone,
I'm trying to build a Unity App to HoloLens which should request a JSON from a Webservice via Rest. The thing is, I want to allow unknown and incorrect certificates. For building in Unity, I therefore us this code:
ServicePointManager.ServerCertificateValidationCallback += (sender, cert, chain, sslPolicyErrors) => true;
The code works fine in Mono, but for .Net 4.5 it doesn't compile. So in that case I use this code instead:
handler = new HttpClientHandler(); handler.ClientCertificateOptions = ClientCertificateOption.Manual; handler.ServerCertificateCustomValidationCallback = (httpRequestMessage, cert, cetChain, policyErrors) => { return true; };
Which should do the same, based on various forum posts. But everytime I try to build for HoloLens I get the following error:
'HttpClientHandler' does not contain a definition for 'ServerCertificateCustomValidationCallback' and no extension method 'ServerCertificateCustomValidationCallback' accepting a first argument of type 'HttpClientHandler' could be found (are you missing a using directive or an assembly reference?)
Is it simply not possible at the moment to turn off the validation or is there another option?
HttpClient doesn't exist in mono at all.
