Read a file line by line
I actually design an application where the users can load points cloud in AR. It works well will small file but when I want to open larger file I've got "Out of memory" error. I Suppose it's because the Hololens can't allocate enough memory in one block. It happen for example with a file of 100Mo even if I have 1Go of RAM available.
I actually use "UnityEngine.Windows.File.ReadAllBytes(filePath);", is it possible to read the file line by line to avoid allocate lot of memory ?
You could try StreamReader or any other file stream reader. Though I am not sure if they load all of the bytes in first or not.
Ok then I read character by character and detect new line by myself ?
Cause I can't see any ReadLine() function with UWP.
This isn't available?
https://msdn.microsoft.com/en-us/library/system.io.streamreader.readline(v=vs.110).aspx
StreamReader isn't available. Only DataReader is available https://docs.microsoft.com/en-us/uwp/api/windows.storage.streams.datareader .
