How to Convert NSF to PST
edited May 2018 in Questions And Answers
The fastest way to migrate Lotus Notes into MS Outlook is ATS NSF to PST Converter because NSF files are not supported in MS Outlook so it becomes necessary to convert into PST format. It allow to save the records into many other formats like EMLX, EML MBOX, MSG, HTML, CSV, vCard, vCal and you also can try its free demo version which permits to access 25 email items from each folder, also if you’re thinking about your large PST files, so you can break it into many small PST files and its highly rich algorithms, make this tool simple to use and 100% effective.
  • edited July 2018
    To convert NSF to PST use MailsDaddy NSF to PST Converter tool. For using the tool there is no need to install Outlook in your machine. It supports all the Lotus Notes editions and outlook editions too. You can download it from here: https://www.mailsdaddy.com/nsf-to-pst-converter/
  • One week ago, one of my friends faced the issue in themigration of Lotus Notes files to Outlook PST and I have recommended him NSF to PST Converter and he is very happy now after getting this tool. You may also use this in your situation.
    For More Information Please Visit:- https://softakensoftware.com/lotus-notes-to-outlook-converter.html
  • There are many applications that will easily convert NSF files to PST without the need of Lotus Notes installation. If you are looking for a third party solution then you can try NSF to PST converter to export NSF archive emails to PST.
  • Don’t get confused. Give a chance to NSF to PST Converter. I assure you for best quality results as the tool was used many times by myself.
    Visit Here : http://www.toolsbaer.com/nsf-to-pst-conversion/
  • In my last company, I was so worriedabout how to safely convert Lotus Notes files to PST format. At that moment, one of my colleagues helped me by providing NSF to PST Converter to me. You can also give a chance to this tool.
    Visit Here: http://www.dailysoft.org/nsf-to-pst.html
  • Sametools NSF to PST Converter is the reliable solution for you. I have used this software a month ago when my father was looking for quick conversion of NSF files to Outlook. You should also try this once.
  • By taking the help of InQuit NSF to PST Converter user easily converts their data into several interesting file formats such as PST, EMLX, MBOX, HTML, vCal, vCard, MSG, CSV, and EML with ease. It is very simple to use even a novice user can easily operate it without any technical skill and knowledge. Apart from it, you store your data into cloud-based application Office365 & Live Exchange Server that is a surplus feature of its. To evaluate its performance you also download a free demo that gives permission to convert 25 emails per folder.
    **Read More Info: ** https://www.inquitsoftware.com/en/nsf-to-pst-converter.html
  • To convert NSF to PST, one needs a tool like eSoftTools NSF Converter which provides the benefits of NSF conversion in multiple formats like PST, HTML, EML, MSG and many others. This tool can perform well fine with any versions of Windows OS and Lotus Notes. Each property of an email can be restored easily without error which can consist of bc, cc, subject, contacts, format, attachments and so on. The data remains in the same tree structure which was present in the original data.
    Know more here: http://www.esofttools.com/nsf-to-pst-converter.html
  • This software program, purchaser can efficaciously export Lotus Notes consumer mailbox into Outlook PST layout with out difficulty. You can export complete Lotus Notes emails, contacts, calendar, to-do lists, notes, journals, and so on. It has many blessings over unfastened NSF to PST converter. It has the ability for saving NSF document in multiple PST files. The user can also migrate particular information using advanced filters designed in the tool. You can apply the automobile-splitting desire on the idea of precise length in MB/ GB. Once the output record reaches the stated document duration, the Lotus Notes export device will routinely put in force report splitting.
    Know more - https://topnsftopst.blogspot.com/2019/01/top-lotus-notes-nsf-recovery-software.html
  • shiv1112shiv1112
    edited February 2019
    I would like to suggest Kernel for Lotus Notes to Outlook Converter software, which can help you to move NSF file to PST file without facing any issues. For more information, visit: https://www.nucleustechnologies.com/lotus-notes-to-outlook.html
  • Lotus Notes is quite popular and feature-rich email client, even though sometimes users need to migrate to MS Outlook for ease-of-use and corporate constraint. There is no direct and straight forward way to export Lotus Notes emails to Outlook PST formats. So i would suggest you to use SysInfo NSF to PST Converter to do flawless conversion.
  • Here is a best tool that can easily convert your NSF file to PST file this Regain NSF to PST Converter software can easily convert your NSF file to PST file.
    Free demo here: https://www.regainsoftware.com/nsf-to-pst-converter.html
  • Download the remarkable Best SysInspire NSF to PST Converter Software which is very easily performed to recover export lotus notes database into NSF file data and convert NSF to PST Outlook file with multiple mailbox formats for example:- emails, notes, calendar, task, contact, inbox items, outbox items, and journal appointments etc. SysInspire NSF to PST Converter software allows users to convert lotus notes to, PST, EMLX, vCard, MBOX, EML, ICS, CSV and HTML etc.
    Explore more info:- https://download.cnet.com/SysInspire-NSF-to-PST-Converter/3000-2369_4-77970319.html
  • demetriodemetrio
    edited March 2019
    You should try Total Webmail Converter introduced by Coolutils. This company is working since 2007, so its secure to use. You just need to install this software and you are good to go. This tool recieves emails directly from your POP3 account and converts them to PDF. HTML, DOC, TXT, TIFF etc. You can get it here - https://www.coolutils.com/TotalWebMailConverter
  • By taking the help of NSF to PST Converter tool users can easily export Lotus Notes to Outlook PST file format with full accuracy. It is compatible to work with all the version of OS Windows version 95, 98, Win NT, Win ME, Win XP, Win Vista, Win 7, Win 8, Win 8.1, and Win 10 (32bit & 64bit). This conversion tool provides a free demo version to convert 25 emails into PST, EML, EMLX, MSG, vCal, vCard, MBOX and CSV file formats.
    Read More Info: https://www.bulkecommerce.com/store/nsf-to-pst-converter-153.html
  • Convert single or unlimited NSF files from Lotus Notes to Outlook PST with full of accuracy. Use Bitdataconversion NSF to PST Converter software to migrate NSF data to PST and as well as EML, MSG, HTML formats. The software flawlessly converts overall NSF files to PST including email messages, attachments, contacts, calendars, tasks, notes and email properties. Download Its free trial version and migrate the first 25 items per folder.
    More details, visit:- NSF to PST converter
  • NSF converter software is helpful for those users who want to convert NSF to PST. This software converts NSF data to PST, EML, PDF, HTML, MSG, etc. Convert NSF to PST software can split large PST to small PST file formats.
    Visit Here:- https://www.kdetools.com/nsf-to-pst-converter.html
  • NSF to PST Converter is the perfect solution for converting unlimited NSF files to PST file without any trouble. You can use this application to get error-free results. Various advance options of the tool make your conversion simple and smooth. The tool works on all Windows versions.
    Visit Here:https://www.osttopstapp.com/nsf-to-pst.html
  • The user can convert NSF file to PST file with the help of a smart tool like eSoftTools Lotus Notes file converter software. A preview is displayed to each user with an option to select the needed items through a checklist. Conversion option is possible into 9 different file types like PST, EML, EMLX, HTML, vCard, MSG, etc. Even PST file can split into many minor PST files. A free demo edition is also offered to all users.
    Explore more here: http://www.nsftopstconverter.esofttools.com/
  • vMail NSF to PST Converter can easily export Lotus Notes all emails, items, folders, into Outlook PST Format. This Software easily to migrate NSF contacts separately in PST file format. Download this application to effortlessly transfer NSF to Outlook PST file with every single data available existing with NSF mailbox.
    More Info;
  • If you want to move your NSF file to PST format, I would like to suggest here Bitacube NSF to PST Converter tool which I had used some day's ago. This tool had provided me a fast conversion process of NSF files to PST format in both single and bulk mode at one time without any hassle. You can check this tool free trial version here: https://bitacube.com/nsf-to-pst-converter.html
  • You can try NSF converter software is the perfect software to converts NSF data to other file formats like PST, EML, MBOX, HTML, PDF, MSG, etc. NSF to PST migration tool migrates meta properties To, Cc, Bcc, subject, tasks, etc. You can try free trails versions here:- http://www.nsf-converter.com/
  • There are two ways that a user can use for converting the NSF file to the PST format. These methods are i) Manual Method and ii) Third-Party tools.
    If you are searching for NSF to PST conversion, then I would suggest for the manual method first. You can perform the method by following the step-step guide I have shared below.
    1. Open Lotus Notes
    2. Now click on File and select Export
    3. Also, choose Comma-separated Value or Structured Text as Save As a type
    4. Now the next step in to import the data in MS Outlook email client, follow the steps given below to perform the same:
    Import CSV file to Outlook
    • Open MS Outlook Email Client
    • Click File >> Open >> Import
    • Select Comma Separated Values and click on Next button.
    • Browse the CSV file that we have created before and choose the appropriate option and press the Next button.
    If you checked the steps that I shared above, then I think you have realized that the Manual method is a very daunting task and time-consuming process. The process cannot be reliable in case of convert the large NSF file. If you have multiple NSF files, then you can’t even think to choose the manual method for the conversion.
    So here, Thirds party tools are the reliable and recommended method for NSF to PST conversion. You can easily convert the multiple NSF files to the Single PST format without worry about the file damage and error. During my research, I found tools like Stellar Converter for NSF, offers to convert any size of NSF file to PST. And through the Software, you can export the NSF file directly to Office 365.
    For more details or to verify the capability of the Software, you could try the demo version of the Software, and you convert ten mail items per folder from the mailbox to PST format in free.
  • According to the latest reviews of tech specialists, the best NSF to PST Converter Tool which is developed by eSoftTools. The tool can recover NSF file data from any type of situation. This software is easy to use and does not require Outlook installation for Lotus Notes file recovery. All items of the mailbox which may contain things like emails, notes, task, journals, calendars, contacts and others. The tree order remains as the original one. A free demo is also provided to all users with support to every single composition of Lotus Notes and Outlook.
    Get More Info:- https://esofttools.com/lotus-notes-to-outlook.html
  • IDC (Instant Data Care) NSF to PST converter software converts your files with emails, calendars, drafts, to-do list, journals, and contacts instantly. This software gives you a smart preview of NSF files and preserves all attachments, email properties and read/ unread status. It converts encrypted NSF files to PST and supports all Outlook- 2019,2016,2013, 2010, 2007 and 2000 and it works to maintain header- To, Bcc, Cc and date. It supports all versions like- 9.0, 8.5, 8.0 and below versions. Lotus Notes mailbox to PST can be done by this free installation tool.
    visit here for more info: https://www.instantdatacare.com/nsftopst/
