Controllers are paired but not connecting
Silverks
Hey,
I just bought WMR Acer headset. The first time setting everything up went smoothly, and I was able to play around in the Mixer Reality Portal for around 20 minutes. Then both of the controllers disappeared.
After that I have tried restarting the computer, factory reset the controllers, replaced new batteries and re-paired them multiple times.
I can get them to add under "Mouse, Keyboard & Pen" and they show up as 'paired' but I cannot get them to actually connect / show up in MRP. I also tried this while changing the USB port used by the Bluetooth stick, to no results.
Any ideas?
Hi Silverks,
You might want to try uninstalling the Mixed Reality Portal and then reinstalling it if you have not tried that already. You can do this by going into Settings -> Mixed Reality -> Uninstall
Additionally, you can get the best connection when the Bluetooth USB is plugged into the front of the computer (if it is a desktop) and ensuring that it is plugged into a USB 2.0 slot, as USB 3.0 generates interference on a similar frequency that can interfere with the Bluetooth connection. Hope that helps!
I´m having this exact problem from time to time. The only fix is by reinstalling the Mixed Reality Portal.
The Bluetooth is internal on the notebook, so don´t know if its usb3.0 or 2.0. Any way to find out?
