Recognize pre scanned room and reload objects on their last locations
Hi!
Is it possible to recognize a pre scanned room, so when I re-enter the room (after closing Hololens for example) it will recognize it and locate the objects on the exact locations as in the previous session?
Thank you in advance!
OptionsPeter_NZ ✭✭✭
Yep, that's what anchors do. You can persist them and reload them on your next session which will place your object in its old location.
