Under what circumstances can the boundary switch not open?
I want to know Under what circumstances can the boundary switch not open?That's to say,Under what circumstances is the boundary switch button gray?
Hi, when you click on the button "Run Setup" (运行安装程序,这里翻译为运行设置可能更好 ) under the "Boundry" Switch. Portal will ask you to choose a mode between "All experienced" and "seated and standing".
Only if when you choose the first option, and complete the rest of setup, the "Boundry" switch can be useful.
Hello,thank you very much! I know what you said.But I want to know why somtimes is the switch off?
