Open Microsoft Edge while running the app
Hello,
I wanted to open Microsoft Edge while running an app with the HoloLens. In my particular case, I'm developing a simple 2D app in Unity, where the idea is to press a button and open a pdf file, image, etc.
Is this possible? what would I need to implement in order to do it?
Thanks in advance!
I think that, generally, the UWP provides you with mechanisms to launch apps from your app either by scheme (e.g. http://) or by file extension (e.g. .png) and then the decision about which app actually handles those things is in the control of the user.
You can see the APIs that are used to do this by looking at the Launcher class and maybe especially the LaunchUriAsync and LaunchFileAsync methods.
So, if you had a file named myfile.html embedded at the 'top level' of your application package then you might be able to write code such as;
in order to launch Edge to display that HTML file.
Hope that helps.
In Unity, I think you can also do:
Application.OpenURL("your url");
Don't know if/how well this would work for local file paths, though.
