Scroll Down & More - PDF Renderer Paroxe
Hello,
Recently I bought the PDF Renderer from Unity, in order to open pdf files in runtime with my app. However, while I achieved to retrieve the pdf file from a website and open it, I can't interact with it with the HoloLens.
More specifically, I open the pdf file but I can't scroll down or do anything with it. Also the cursor disappears every time I gaze on the pdf.
Do you know what may be the problem? or how to scroll down and do the other interactions with the pdf?
Thanks in advance!
Optionsmark_grossnickle ✭✭✭
I believe we created custom controls. Their SDK wouldn't be listening for manipulation or navigation gestures so you will need to implement them. Or if you aren't trying to implement pinch and drag to scroll then you could just create next/back buttons to change the page.
