HoloLens Arduino Bluetooth
Hi guys,
I want to connect an Arduino using a BlueSMiRF Bluetooth module to my HoloLens.
For that puspose I found an UWP example:
https://developer.microsoft.com/en-us/windows/iot/samples/btserial
Unfortunately, it is not working, not even on the PC. The returned RfcommDeviceService is always null.
Any idea how to fix this is greatly appreciated.
jschnettker
    I started a Unity project, to test the logic behind my app: just a sphere, and I want to manipulate it's width via Bluetooth. This example gave me another lead for finding Bluetooth devices:
    https://github.com/Microsoft/Windows-universal-samples/tree/master/Samples/DeviceEnumerationAndPairing
    In scenario two, it this sample my RN41 under Bluetooth.
    Also, my custom GetDevicesAsync() function retrieves three devices, that have the same name, I gave the Bluetooth module. But it retrieves none of them, when I use a AQS, that lists all serial port rfcomm services. Therefore, I'm almost sure, that one of these devices has any type of rfcomm service, no matter, which. According to this, I implementet error handling, that when the connection to one device fails (because it has no rfcomm service), it continues with the next one.
    But it seems, that this is not enough, every time I run it, I get the following output:
    14 devices found
    Trying to cennect with Bluetooth module
    Executing TryConnectAsync
    Selected device is not null.
    Exception thrown: 'System.Exception' in mscorlib.ni.dll
    Couldn't return RfcommService
    False
    Didn't break
    Exception thrown: 'System.InvalidOperationException' in mscorlib.ni.dll
    The program '[5608] serialinput.exe' has exited with code -1073741189 (0xc000027b).
    How could I handle this error, to make it continue trying to connect to other devices? This is the code I'm currently using:
    `using UnityEngine;
    using System;
    using System.Collections;
    if UNITY_EDITOR
    using System.IO.Ports;
    elif NETFX_CORE
    using Windows.Devices.Enumeration;
    using System.Threading.Tasks;
    using Windows.Devices.Bluetooth;
    using Windows.Devices.Bluetooth.Rfcomm;
    using Windows.Networking.Sockets;
    using Windows.Storage.Streams;
    using Windows.Foundation;
    using System.Collections.ObjectModel;
    endif
    public class SizeManipulator : MonoBehaviour
    if UNITY_EDITOR
    public SerialPort serialPort = new SerialPort("COM9", 9600, Parity.None, 8);
    elif NETFX_CORE
    private DeviceInformationCollection deviceInformationCollection;
    private DeviceInformation deviceInformation;
    private string DeviceEnumerationAqsString;
    private RfcommDeviceService deviceService;
    private StreamSocket streamSocket;
    private BluetoothDevice BlueSMiRF;
    private IReadOnlyList<RfcommDeviceService> RfcommDeviceServices;
    public DeviceWatcher deviceWatcher;
    private TypedEventHandler<DeviceWatcher, DeviceInformation> handlerAdded = null;
    private TypedEventHandler<DeviceWatcher, DeviceInformationUpdate> handlerUpdated = null;
    private TypedEventHandler<DeviceWatcher, DeviceInformationUpdate> handlerRemoved = null;
    private TypedEventHandler<DeviceWatcher, System.Object> handlerEnumCompleted = null;
    private TypedEventHandler<DeviceWatcher, System.Object> handlerStopped = null;
    bool connected=false,connecting=false,continuing=false;
    public ObservableCollection<DeviceInformation> resultCollection
        get;
        private set;
    public ObservableCollection<DeviceInformation> connectionCollection
        get;
        private set;
    endif
    public static string strIn;
    private string inputString;
    private float size;
    Vector3 startScale, scaleManipulation;
    void Start()
    if UNITY_EDITOR
        OpenConnection();
    elif NETFX_CORE
        streamSocket = new StreamSocket();
        resultCollection = new ObservableCollection<DeviceInformation>();
        connectionCollection = new ObservableCollection<DeviceInformation>();
        StartWatcher();
    endif
        startScale = new Vector3(transform.localScale.x, transform.localScale.y, transform.localScale.z);
        scaleManipulation = new Vector3(0f, 0f, 0f);
    void Update()
        inputString = string.Empty;
    if UNITY_EDITOR
        inputString = serialPort.ReadLine();
    elif NETFX_CORE
        //GetDevicesAsync();
        try
            if(!connected&&!connecting)
                connecting=true;
                connectionCollection=resultCollection;
                Debug.Log(connectionCollection.Count+" devices found");
                AsyncConnectionHandler();
        catch(Exception)
            Debug.Log("Error in Update Function");
            return;
    endif
        if (inputString != string.Empty)
            Debug.Log(inputString);
        inputString += ".0";
        scaleManipulation.x = (((float.Parse(inputString)) / 1023) - 0.5f) * startScale.x;
        transform.localScale = startScale + scaleManipulation;
    if UNITY_EDITOR
    public void OpenConnection()
        if (serialPort != null)
            if (serialPort.IsOpen)
                serialPort.Close();
                Debug.Log("Closing port, because it was already open!");
            else
                serialPort.Open();
                serialPort.ReadTimeout = 50;
                Debug.Log("Port Opened!");
        else
                print("Port is already open");
            else
                print("Port == null");
    elif NETFX_CORE
    private void StartWatcher()
        resultCollection.Clear();
        DeviceEnumerationAqsString=string.Empty;
        deviceWatcher=DeviceInformation.CreateWatcher();
        handlerAdded = new TypedEventHandler<DeviceWatcher, DeviceInformation>((watcher, deviceInfo) =>
                resultCollection.Add(deviceInfo);
        deviceWatcher.Added += handlerAdded;
        handlerUpdated = new TypedEventHandler<DeviceWatcher, DeviceInformationUpdate>((watcher, deviceInfoUpdate) =>
                foreach (DeviceInformation deviceInfo in resultCollection)
                    if (deviceInfo.Id == deviceInfoUpdate.Id)
                        deviceInfo.Update(deviceInfoUpdate);
                        break;
    ` deviceWatcher.Updated += handlerUpdated;
    handlerRemoved = new TypedEventHandler<DeviceWatcher, DeviceInformationUpdate>((watcher, deviceInfoUpdate) =>
                    resultCollection.Remove(deviceInfo);
                    break;
        deviceWatcher.Removed += handlerRemoved;
        handlerEnumCompleted = new TypedEventHandler<DeviceWatcher, System.Object>((watcher, obj) =>
        deviceWatcher.EnumerationCompleted += handlerEnumCompleted;
        handlerStopped = new TypedEventHandler<DeviceWatcher, System.Object>((watcher, obj) =>
        deviceWatcher.Stopped += handlerStopped;
        deviceWatcher.Start();
    private async void GetDevicesAsync()
        DeviceEnumerationAqsString=RfcommDeviceService.GetDeviceSelector(RfcommServiceId.SerialPort);
        deviceInformationCollection=await DeviceInformation.FindAllAsync(DeviceEnumerationAqsString);
        foreach(DeviceInformation device in deviceInformationCollection)
            Debug.Log(device.Name);
            if (device.Name=="RN41-Jonas-CBEC")
                Debug.Log("Device RN41-Jonas-CBEC found");
                try
                    BlueSMiRF=await BluetoothDevice.FromIdAsync(device.Id);
                catch(Exception)
                    Debug.Log("BlueSMiRF is no Bluetooth device");
                Debug.Log(BlueSMiRF.BluetoothAddress);
                connected=await TryConnectAsync(device);
    private async Task<bool> TryConnectAsync(DeviceInformation selectedDevice)
        Debug.Log("Executing TryConnectAsync");
        if (selectedDevice!=null)
            Debug.Log("Selected device is not null.");
            try
                deviceService = await RfcommDeviceService.FromIdAsync(selectedDevice.Id);
                Debug.Log("returned device service");
            catch(Exception)
                Debug.Log("Couldn't return RfcommService");
                return false;
            if (deviceService != null)
                Debug.Log("Try to connect to device");
                try
                    await streamSocket.ConnectAsync(deviceService.ConnectionHostName, deviceService.ConnectionServiceName);
                    Debug.Log("Socket connected");
                    return true;
                catch(Exception)
                    Debug.Log("Couldn't connect streamSocket");
                    return false;
            else
                Debug.Log("Didn't find the Rfcomm service.");
                return false;
        else
            Debug.Log("Didn't find device");
            return false;
    private void StopWatcher()
        if (null != deviceWatcher)
            deviceWatcher.Added -= handlerAdded;
            deviceWatcher.Updated -= handlerUpdated;
            deviceWatcher.Removed -= handlerRemoved;
            deviceWatcher.EnumerationCompleted -= handlerEnumCompleted;
            if (DeviceWatcherStatus.Started == deviceWatcher.Status ||
                DeviceWatcherStatus.EnumerationCompleted == deviceWatcher.Status)
                deviceWatcher.Stop();
    private async void AsyncConnectionHandler()
        foreach(DeviceInformation device in connectionCollection)
            try
                if(continuing)
                    Debug.Log("Continuing");
                    continuing=false;
                if(device.Name=="RN41-Jonas-CBEC")
                    Debug.Log("Trying to cennect with Bluetooth module");
                    Debug.Log(connected);
                    if(connected)
                        break;
                    Debug.Log("Didn't break");
                    continuing=true;
            catch(Exception)
                Debug.Log("Exception thrown at device namecheck.");
                continue;
        connecting=false;
    endif
    void OnApplicationQuit()
    if UNITY_EDITOR
        serialPort.Close();
        Debug.Log("Port closed!");
    elif NETFX_CORE
    StopWatcher();
    endif
    I have no idea, how to catch this errors or how to continue.
    The code I use is partially form the following examples:
    https://github.com/ms-iot/samples/tree/develop/BTSerial
    https://code.msdn.microsoft.com/windowsapps/Bluetooth-Rfcomm-Chat-afcee559
    Any help about fixing this is greatly appreciated.
    Thank you in advance,
    jschnettker
    Hi...in my case I have been able to get this to work when my Build Platform is PC Standalone, because I am able to use the System.IO.Ports namespace and it is easy to just read the data that is sent to the SerialPort.Unfortunately, the WSA platform does not allow the use of the System.IO.Ports namespace (among many other limitations).How do I get this string of data to be sent to the game when the target platform is WSA?
    You have to use RfcommDeviceService, as this is the only way to open a serial port on the Hololens.
    The most important trick is to make sure, that your app has the user consent to open the Bluetooth device. This can be the user consents dialog (I had some problems there too: https://forums.hololens.com/discussion/comment/19578#Comment_19578 )
    or do it manually every time you deploy your app in the "Settings->Privacy->Other devices", where you have to enable your app.
    I'm not sure if you are having exactly the same problem as I was, but I found that for some reason the RfCommDeviceService would always return null when it was executed on a thread other than the UI. I managed to fix this in Unity by invoking the method where I have "RfcommDeviceService.FromIdAsync(device.Id)" on the UI thread.
    UnityEngine.WSA.Application.InvokeOnUIThread(GetService, true);
    private async void GetService()
            _service = await RfcommDeviceService.FromIdAsync(device.Id);
