What does the tracking camera in HP MR headset record?
Good day everyone,
I have a HP Mixed reality headset with the required system specs as mentioned in https://goo.gl/w35F86 and have installed all the tools to build Windows MR apps (https://goo.gl/yP0HH2).
I just started working on a project which requires mixed reality and pardon me if I sound naive. I'm able to see the Cliff house in the headset. I'm also able to create simple scenes in Unity and run it on the headset. But now I'd like to work on the real world data and I can't find the API which extracts the real world video from the 2 cameras in the headset.
I was hoping to record video from the two cameras in the headset and I have these doubts -
- Do they really record videos or is it just a tracking camera? What type of camera is it and how does it function?
- If its not possible to record video like mentioned above, what is the best alternative to do it?
It'd be really helpful if anyone could point me in the right direction to create mixed reality apps.
Thanks in advance!
Jimbohalo10 ✭✭✭
Hi @akshay
The code is obtained from the samples in the Unity Asset Store.
Tutorials do not contain examples on video recording
Search the forums for "360" "degree" "video" for recommendations
You cannot use HP headset cameras as they are depth sensing cameras.Look at the Spectator project on GitHub for video recording with MR
5 -
MAK ✭
@akshay said:
Good day everyone,
I just started working on a project which requires mixed reality and pardon me if I sound naive. I'm able to see the Cliff house in the headset. I'm also able to create simple scenes in Unity and run it on the headset. But now I'd like to work on the real world data and I can't find the API which extracts the real world video from the 2 cameras in the headset.I was hoping to record video from the two cameras in the headset and I have these doubts -
Thanks in advance!The Windows MR HMDs don't have RGB cameras (only the HoloLens has one) but have 2 Depth Sensing cameras. So you won't be able to "record" anything. The best you could do is extracted the reconstructed mesh that the cams are tracking but this is not possible yet in the APIs (unlike on the HoloLens).
Hi @akshay
That is not completely true. Windows MR HDMs do not have RGB camera, but they don't have depth sensing cameras either (only the HoloLens do have these ) They do have low quality black and white cameras however. But I'm not even remotely sure if it is possible to get the raw data or if all the tracking calculations are already done within the headset. My guess is that it might be possible to get the raw camera data somehow, but probably not easily.
Source: https://docs.microsoft.com/en-us/windows/mixed-reality/enthusiast-guide/tracking-system
That is not completely true. They don't have RGB cameras, but they also don't have depth sensing cameras (only the HoloLens do have these ). They do have two low quality black and white cameras, however. If the calculations aren't done within the HMD and discarded immediatly, it could be possible to grab those images. Might still be a difficult task, if possible at all.
Oh great... first my comments don't show up or disappear after 5 Seconds, and days (about two weeks) later they get here all at once. Sorry for all the spamming.
