Access to a file in Unity project folders in Hololens.
CCorona
I'm making a Holographic App using Unity, I need to read data from a file that is in file located at: "Assets/Myfile.txt" (It could be different type of file, not only .txt so TextAsset isn't a valid option), so the problem is that with my current code I can see what I want in the Unity editor, but When I compile and export the project to a VS Solution and run in the HoloLens device It show's nothing (just a little lag, maybe for a Exception).
Any Ideas?
This is my code:
using System.IO;
public long readFile(string path) { FileInfo f = new FileInfo(path); print("Tamaño del archivo en KB: " + f.Length / 1024); return f.Length / 1024; }
My current path is:
string path = "Assets/ModelInfo.txt";
PS: I added the External Storage capability to my App manifest.
Hey @CCorona ,
have you tried using it as a resource? https://docs.unity3d.com/ScriptReference/Resources.Load.html
Regards
@pstueven
