Unable to move 3D model after latest update
Dear all,
I have been using the 3D Viewer Beta app with no problems for the last months. However, since the last update, I lost the ability to move the 3D model with my finger (in a drag & drop fashion). Now, the only way to move the model is by moving my head (sideways and up/down). This results in not being able to move the model to the exact place I want it to be.
I was finally able to export my 3D models in 1:1 scale with animations a couple of weeks ago, but now I just can't position them where I want.
Is there any way around this?
1
I have similar scaling problems. The slider does not work anymore. Also easy positioning by clicking on the object is not working anymore like the way it used to work Is this a bug ? Hope Microsoft can solve this by a roll back to previous version that worked well around march 2018? Maybe someone knows a different free app with similar functionality. Thanks !
