SpatialUnderstanding MeshRenderer color change during run-time
Boku
Hi guys,
I'm currently working with SpatialUnderstanding, which is a module for the Microsoft HoloLens. Within the module, mesh of the space the user is currently in is mapped (essentially a processed spatial map). I'm looking to modify the mesh material color during run-time, but the following code I have seems to have no effect (visually):
void TestFunction() { List<MeshRenderer> roomMeshRenderers = SpatialUnderstanding.Instance.UnderstandingCustomMesh.GetMeshRenderers() as List<MeshRenderer>; foreach (currentRenderer in roomMeshRenderers) { Material material = currentRenderer.material; Debug.Log(material.color); material.color = Color.white; currentRenderer.material = material; } }
Would appreciate it if anyone could point why this code has no effect.
pstueven ✭✭
Hey @Boku ,
To be honest I am not into materials that much. So I am just giving suggestions here:
Are you sure the current material has a texture called "_MainTex" applied? The first argument of SetTexture determines which texture you want to set. Maybe try using "_BumpMap" or Material.mainTex .5
Hey @Boku ,
I did something similar with but also used spatialUnterstanding in that scenario. Try this:
SpatialUnderstandingCustomMesh spatialMesh = GameObject.Find("SpatialMapping").GetComponent<SpatialUnderstandingCustomMesh>(); foreach (SpatialMappingSource.SurfaceObject surfaceObject in spatialMesh.SurfaceObjects) { surfaceObject.Renderer.material = material }
Of course you need to adjust the string "SpatialMapping" to the name of the object holding your SpatialMapping
Regards
@pstueven
Hey @pstueven
That works and changes the material. I found out there is already a function available in SpatialUnderstandingCustomMesh.cs which does this, called "MeshMaterial".
I have a slightly different problem however, when I try to change the texture of the material to be rendered the new texture doesn't seem to get applied. The code is as follows:
SpatialUnderstanding.Instance.UnderstandingCustomMesh.ChangeProcessedMeshTexture(targetTexture);
And in SpatialUnderstandingCustomMesh.cs I have:
public void ChangeProcessedMeshTexture(Texture2D targetTexture) { for (int i = 0; i < SurfaceObjects.Count; ++i) { SurfaceObjects[i].Renderer.material.SetTexture("_MainTex", targetTexture); } }
Hey @Boku ,
That was the problem! My shader didn't have a _MainTex. Think I'll have to use another shader.
Thanks
