download folder
Hi, Does anyone know how through the app I get to the download folder of the Hololens?
(I want to load a file that I transferred through the USB cable)
-1
Optionsmtaulty ✭✭
You're welcome :-) Take a look at the application capabilities that you need to specify in your application manifest here.
If you're working in Unity then there's a section in the editor that also lets you specify these capabilities so that when Unity generates the Visual Studio project it already has them populated correctly for you.
Hope that helps.
Hi. If I understand you correctly, I think you may hit upon the situation where a UWP app is only allowed to read the files from the downloads folder that it created in the first place (see the docs here for info).
This would be different to (say) the pictures folder which can be accessed via the KnownFolders class if the app has the right permisions/capabilities set to allow it.
The only way I can think of getting around that if you really need the downloads folder is to open a file dialog and let the user select it themselves from the downloads folder as I think that would work.
Hey thanks for the help
How do I get permissions to the known folders?
" StorageFolder appFolder = KnownFolders.Objects3D;"
After that, I can not access the files in this folder
Hope that helps.
