[OSX Parallels] Emulator crashes with memory management blue screen
samdish
I'm unable to get my emulator running. It keeps crashing with this bluescreen:
Happens both while launching it from VS as well as Hyper-V Manager. Searching online hasn't yielded any help so far. I've already taken care to:
- enable virtualization support in Parallels
- enable Hyper-V in the Windows VM
- pump as much RAM (4GB) into the emulator as I safely can
Any ideas, folks?
Here's my setup:
Host system:
Parallels:
Parallels virtual machine running Windows 10:
Hololens Emulator on VM:
samdish ✭
After a few days, I couldn't get it to work on Parallels. Imported the Parallels VM file (.pvm) into VMWare Fusion and the emulator runs like a charm. -1 for Parallels virtualization, for me at least.
BSODs are also known as Blue Screen of Deaths which is very common among in Windows users. It actually a major error caused a system crash and Windows cannot recover from it. Tip: You can use antivirus to Scan your system because the problem might be the damaged system files and these files are damaged because of a virus. Method 1: Check RAM: You need to check your RAM and unplug the ram, clean it and then plug in again. Because sometimes dust on RAM also caused this error.
Method 2: Clear CMOS: Clearing the CMOS battery is a solution that has worked for a lot of users.
Method 3: Run SFC: You need to Run SFC and to acknowledge the complete procedure to this method, must follow https://appuals.com/memory_management-bsod-blue-screen/ because it will help to get rid of this error.
