How to get motion controller transform
Do you know how to get current effective motion controller transform?
I'm using this for now.
forearch(var sourceState in InteractionManager.GetCurrentReading())
Vector3 controllerpos
sourceState.sourcePose.TryGetPosition(out controllerpos);
I want to get controller's transform, not only position.
  • thank you.
    It works for me!
  • here is my rough guess, haven't been able to run VR preview yet with my Vive CV1. But controller idea is pretty much the same. You are in a Pawn, you need to get the pawn owner(a PlayerController), and then get the player index from there(on server), then set the index.
    I will have to setup my UE4 first, and possibly just compile from github source to make it work, cause both UE4 and SteamVR is a moving target, compile and update is probably a safe bet.
    It's hard to even find someone that have a vive to do multiplayer test I guess, so gotta find a buddy soon.(I have a few in local indie dev group that owns pre dev kit, so I can ask them to test with me once I got a build going.)
    edit: oh, and I don't know about the answer to 2nd question. not even a guess.
