Hololens cannot pinvoke native dll with error "Dll Not Found"
I tried to build a very simple native dll that can be called by a simple UWP c# app with PInvoke. The UWP app can run on normal Windows 10 computer without any problem, but when I deployed the UWP app to a Hololens, it always fails with error "Dll Not Found". I have tested RS4 and RS5 in Hololens and got the same result.
The reproduce steps are very straightforward.
- Create a native C++ DLL project ( I am using VS 2017 community version), and write some code like returning 1 + 2, for example:
include "stdafx.h"
extern "C" {
__declspec(dllexport) int __stdcall add12() { return 1 + 2; }
- Create a blank UWP project to call the DLL function with PInvoke:
public class WrapperClass
[DllImport("CPPDLL", CallingConvention = CallingConvention.StdCall)]
public static extern int add12();
public sealed partial class MainPage : Page
public MainPage()
this.InitializeComponent();
int result = WrapperClass.add12(); Debug.WriteLine("add 12 = " + result); } }
- Build and run the UWP application on a Win10 computer and a Hololens, and you will notice that the Win10 computer will succeed to run while the Hololens will fail to run.
Any help is highly appreciated.
Bin
OptionsBinXie ✭
Got the answer from somewhere else. The problem is about dll dependency. Question closed.
BinXie Could you share how you solved it?
I got the same problem and Did you refer to this https://social.msdn.microsoft.com/Forums/windowsapps/en-US/26013e5e-3ff1-44a0-8797-0474dabd12d0/uwpincluding-dlls-in-a-uwp-application-in-visual-studio?forum=wpdevelop?
Cause I have no Idea how to do the dependency thing after read that thread. Cause I have no option for package dependency in appxmanifest.
