How to save spatial mapping data on hololens ?
Hello All,
This is scenario,
1) l have two buttons 1) Scan Room 2) Load Room
2) When user air tap on scan room spatial mapping start. After 30 sec spatial mapping data
save with current date time.
3) Again i air tap on scan room start scanning process and save mesh with date and time.
4) When i air tap on Load room there generate thumbnail dynamic in basis of scanned room.
5) After that air tap on first room it will load first scanned room when air tap on second room then load second vice versa
So, is it possible ? and how can i achieve ? please help.
thanks,
Ankit Sangani
hey@Ankit09_Sangani, Do you achieve it,and now i want to get it. Thanks
@water_99 you could potentially export the mesh as an Obj and use world anchors to align it after loading. Or just simple save the vertices of the mesh and recreate it when needed. There is obviouslly exporting through the online portal.
Ok!thanks,got it!
