Unable to start photo mode
When I tried to deploy my code to the HoloLens, everything is right. But when I try to use HoloLens app to give a live stream to share with others, there is something wrong and shows that 'say: unable to start photo mode'. I am quite confused because the only thing I do is connect with live stream. I've check the capabilities and ensure that webcam is included. Can anyone give me some advice in this situation? Thank you!
Hi @sophialu,
There is some issues with photo API with RS4, Unity will deploy a fix soon apparently, here is the post https://forum.unity.com/threads/hololens-photo-capturing-failing.548845/#post-3826153
If you're not on RS4, you can check if you also check microphone capability .
