Hololens cannot pinvoke native dll with error "Dll Not Found"
I tried to build a very simple native dll that can be called by a simple UWP c# app with PInvoke. The UWP app can run on normal Windows 10 computer without any problem, but when I deployed the UWP app to a Hololens, it always fails with error "Dll Not Found". I have tested RS4 and RS5 in Hololens and got the same result.
The reproduce steps are very straightforward.
  1. Create a native C++ DLL project ( I am using VS 2017 community version), and write some code like returning 1 + 2, for example:
include "stdafx.h"
extern "C" {
__declspec(dllexport) int __stdcall add12() {
    return 1 + 2;
  1. Create a blank UWP project to call the DLL function with PInvoke:
    public class WrapperClass
    [DllImport("CPPDLL", CallingConvention = CallingConvention.StdCall)]
    public static extern int add12();
public sealed partial class MainPage : Page
public MainPage()
this.InitializeComponent();
        int result = WrapperClass.add12();
        Debug.WriteLine("add 12 = " + result);
  1. Build and run the UWP application on a Win10 computer and a Hololens, and you will notice that the Win10 computer will succeed to run while the Hololens will fail to run.
Any help is highly appreciated.
Bin
    BinXieBinXie
    Answer ✓
    Got the answer from somewhere else. The problem is about dll dependency. Question closed.
