Conversion PST to MBOX
There is any solution to get my bulk of PST files transfer to Thunderbird (mbox) please suggest some tool because its not possible for me to do this one by one
    Softaken PST Mailbox Converter converts PST to various other formats with just a few simple steps including MSG, MBOX, EMLX and EML formats. This tool has been designed keeping mind a user-friendly experience.
    Key features:
    Converts PST to MBOX, MSG, EMLX and EML formats
    Migrate PST contacts to VCF(VCard)
    Support Multiple languages
    Preview of Converted Items
    Accurate data conversion
    Work On the password protected Files
    Work with old new MS outlook (ANSI/Unicode) PST types
    High-Quality compatibility
    Demo version to try
    PST to MBOX Converter for Mac is a tool which can effortlessly migrate your PST documents into outlook MBOX without problems. It is a not unusual record format in order that most of the customers need to get right of entry to it via outlook that is commonly used email customer. This software program deals with the email messages and file attachments in PST file layout to transform them into MBOX format easily with none records loss. Visit here for more details:- http://www.toolscrunch.com/mac-pst-to-mbox-converter.html
    Thanks for the suggestion. I want to suggest another software that I used to convert my Outlook PST files to MBOX. The tool is DataVare PST to MBOX Converter and is extremely easy to use, supports batch migration and maintains data integrity throughout the conversion process.
    You can give a try to PST to MBOX Converter that provides easy, exact and batch migration of multiple Outlook PST files into MBOX format, which you can easily access in different email applications - Thunderbird, Mac Mail, OperaMail, Spicebird and many more.
    Try PST to MBOX Converter - one of the best utilities which provides simple and easy method for users to easily convert Outlook PST files to MBOX format for any Outlook edition i.e. Outlook 2019, 2016, 2013, 2010, 2007, etc. The PST to MBOX Converter is suitable with all Windows OS platforms such as Windows 10, 8.1, 8, 7, XP, etc. to convert PST files to MBOX format without any issue. It gives dual modes - Single mail conversion and Batch mails conversion mode to convert Outlook mails to MBOX format in one-time process. The software is compatible with all MBOX supported email clients to convert Outlook emails from any MBOX supported email client to other format without any difficulty.
    CheckOut this Software and easily convert your PST file to MBOX file.
    Try this Software free demo version from here: http://www.psttomboxconverter.emltopstutility.com/
    I'd like to reply on this topic 'conversion PST to MBOX'. You can use third party software PST to MBOX Converter. In this PST to MBOX Converter tool easily convert PST files to MBOX, and other file formats such as MSG, EML, EMLX, HTML, etc. This Software supports both ANSI & UNICODE file type. PST file also maintains Meta properties such as (to, cc, bcc, subject, from & attachment) after convert mail no data will be change. It is compatible with all versions of MS Outlook and Windows.
    If you want to convert outlook PST file into MBOX file format. Then you should try KDETools PST to MBOX conversion software. This software allows the user to convert PST file into multiple file formats like PST to EML MSG EMLX HTLM etc. It is a useful software that lets you convert PST to MBOX file formats. By using this third party software you can easily import all Outlook PST data into MBOX file formats without any data losing. It supports all MS Outlook versions.
    For more information, you can visit our site: https://www.kdetools.com/pst-to-mbox-converter.html
    Get perfect solution to convert PST file to MBOX format. Converted file can be used in any MBOX supported platform.
    Visit to get more: http://www.axblaze.com/products/psttombox-converter.html
    MBOX to PST exportation is not possible with the manual method so we need a trustworthy tool to convert MBOX files into PST format. I would like to suggest you to the best third party software which is KDETools MBOX to PST Converter. This software is an effective tool that enables advanced email conversion from MBOX to PST format. It can convert MBOX file into multiple file formats like PST, MSG, EML,EMLX,HTML etc.
    KathyKathy
    edited April 2019
    If you are looking for an instant and hassle-free solution to implement PST to MBOX conversion. Then, without any doubt, simply make the best use of Outlook PST to MBOX Converter. This tool can be easily installed on both Windows and Mac machine to convert PST files to MBOX format without worrying about data loss issue.
    Users can download the free demo version from the below mentioned link:
    https://www.systoolsgroup.com/outlook-to-mbox.html
    Give a Try to ZOOK PST to MBOX Converter for 100% accurate and reliable conversion from PST to MBOX format. It allows to batch convert PST to MBOX format at once to export email, contacts, calendars, tasks, etc. from Outlook PST to MBOX format. It allows you to move entire Outlook data items into MBOX format in few moments.
    Advance Features of PST to MBOX Converter: -
    • Batch Export PST to MBOX format at once.
    • Provides complete conversion from Outlook to MBOX.
    • Preserves email formatting during conversion.
    • Folder structure will remain intact.
    • Supports all Outlook editions to convert PST files.
    • Easy to Use Interface for non-technical users.
    Download Source: - https://download.cnet.com/Zook-PST-to-MBOX-Converter/3000-2369_4-77394418.html
    Being a non-technical user, I have used lots of manual methods but not getting satisfied with any of the methods and I found its not effective so I used Outlook Converter PST to MBOX Converter which is suggested by my friend, and I got best results.
    You must go for this tool because it provide PST files to MBOX, MSG, EML, EMLX, and VCF formats.
    You must try this tool:- https://www.toolsground.com/outlook-converter/
    Looking for some reliable and cost-effective tool to convert PST to MBOX format? Try PST to MBOX Converter software which effectively migrates Outlook PST file to MBOX file format without having any trouble. It can also save the PST file into various file formats such as MBOX, EML, MSG, EMLX, and HTML.
    • Supports multiple saving options.
    • Supports all versions of MS Outlook and Windows.
    • Split PST file by Date, Size, and Folder.
    • Selective conversion option
    • Retain Meta Data and Properties
    • Import PST to Office 365 and a Live Exchange Server
    Download for free and install: http://www.howtosol.com/products/pst-to-mbox-converter.html
    Rendering to me, GainTools PST to MBOX Converter Tool is the best migration app for switching numerous Outlook PST files data in MBOX or many other formats. The software preserves the complete data folder structure during the progression. In addition, you can also effort its free trial version to check it’s working. The demo edition of PST to MBOX Software consents users to transfer the first 10 items from each folder.
