Unity: Getting the file list and download the file in oneDrive on HoloLens
Musa
Hi guys,
Is there any code example or any suggestion that allow me to access oneDrive and get the file list/ folder list, and the download single file or multiple file to local storage on HoloLens?
I prefer not using the FilePicker because in that case I will have to jump out from my app and then jump back in. I want everything to be done inside my app.
Or FilePicker could do everything without opening a new window?
I had to open some files for an app. I used the folderpicker because when I tried to access file using System.IO I Always got permissions denied, even If I set the capabilities to access the folder (Documents, Pictures..etc)
So my advice would be to stick with the pickers5
