[UWP]WebRTC issue - Hololens unable to send video offer
FranzFranz
edited November 2018 in Questions And Answers
Hello,
we developed a fully working webRTC UWP environment starting from this project (https://github.com/webrtc-uwp/PeerCC/tree/Mosa/20180320-peercc-unity).
We developed a Desktop app and a HoloLens app to communicate with each other. Everything was good until we moved to a custom server (Xirsys in this case).
We then modified the Signalling script to adapt it to the new server which uses the MessageWebSocket instead of the StreamSocket that we used before with the peerccconnection_server.exe included in the sample demo.
The current scenario is:
-Desktop connects to the server and waits for peers.
-Hololens connects to the server and is added to the available peers' list.
-Desktop can now call the Hololens and start communicating.
Hololens should send both audio and video, while Desktop only sends audio.
The actual problem now is the hololens is not able to send the video offer, so the app freezes and crashes. Audio is still working fine (just a few secs before the crash).
If we try communicating between two Desktop clients everything works like a charm.
It would be appreciated some help to solve the problem.
    NEWS: if we disable the video streaming from Hololens, setting the RTCMediaStreamConstraints.videoEnabled to false, the app works great streaming only audio both ways.
    So the problem occours when trying to use the Hololens camera.
    new update:
    I put the constraints back to true for both clients, then I disabled _selfVideoTrack on the Desktop and try. The result is that now hololens streams audio and video correctly, desktop receives them and streams audio to Hololens (and it receives it), BUT, all the UI on hololens disappears and we get:
    An unhandled exception of type 'System.AccessViolationException' occurred in xxx.exe
    Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
    in the hololens client, in this method:
    public void Run()
    m_AppCallbacks.Run();
