HoloLens can't connect to Win10 WiFi Hotspot of Laptop
Hi there,
I updated my Hololens to the October Update some days ago.
Now, if I set up a WiFi Hotspot on my Win10 laptop, the HoloLens won't connect to this hotspot anymore. It tries for a few seconds, then tells me "can't connect to this network".
I also tried this using other Win10 PCs, with the same result.
With the older April Update, the connection would work without any errors.
Is this a known issue?
It's pretty urgent that this gets fixed (in my opinion), as it is the most stable and fastest way to do a live mixed reality capture.
Help is appreciated! :-)
Thank you!
I noticed the same issue…
Same here. It's quite a problem for our mobile Hololens display....
