The Perfect Way to Convert EDB Files to PST
Converting EDB files to PST format has always remained a tough task. But if a proper method is followed then the conversion of EDB to PST can be done easily. There are two methods by which Exchange Server Database files can be exported to Outlook PST. These are
- Convert EDB to PST with Exmerge.exe
Use Powershell to convert EDB to PST
These two methods differ on a large scale as in PowerShell the user should have knowledge of Cmdlets and database commands but the Exmerge method is easy to execute. This can be done by following steps
Converting the EDB to PST with Exmerge.ExeLaunch the Exmerge.exe tool and sign in to Exchange Server
- Click on next to proceed further and a new window will prompt up
- Click on the option Extract or Import (2 step process)
- This will extract the data from the EDB file, click on Next
- Click on the Import Procedure tab and option 'Archived data to target store'
- Enter the details of the folder from where EDB files are to be moved and select the mailbox, click on Next
- Click on Change folder to select the folder to store converted PST file
- The process will start and an alert box will open when it gets complete
- Finally, click on the Finish to abort the process
The EDB files will be moved to Outlook easily. In this way you can export the database files to Outlook PST
Don’t go anywhere for searching a perfect way to convert EDB files to PST simply use “Enstella EDB to PST Converter Software” it’s a complete solution to convert EDB files to PST and other formats (EML, MSG, and HTML). It easily extract EDB data into another format with Emails header information (to cc, bcc, date time and subject). EDB to PST Software gives much functionality for users while conversion. EDB to PST Converter Software perfectly works in all windows and MS Exchange version.
Note: Enstella Exchange Recovery Software is available at lowest price $99.
Read more: enstella.com/edb-to-pst-conversion.html
For a tried and tested exchange recovery tool that provides an effective solution for all exchange recovery needs try EdbMails. EdbMails offers unparalleled features like private and public folder recovery and archive folder migration to office 365 and Live exchange server. It is one of the most reliable Exchange EDB to PST Converter software in the market that makes use of its advanced deep scanning mechanisms to recover most data out of corrupt/inaccessible exchange databases and convert them into Outlook PST file without any loss of original database.
EDB to PST conversion software is the perfect way to convert EDB to PST file. There are lots of professional software available on the Web, which can easily do this conversion task, Kernel for EDB to PST Converter is such tool. It also supports to repair damaged EDB file and recover deleted mailbox items. Try it: https://www.nucleustechnologies.com/edb-to-pst.html
