Announcing HoloLens Preview 17763
Todd
mod
Hi HoloLens Insiders,
Today we’re publishing a new RS5 Insider build for HoloLens, 17763, with incremental bug fixes and stability improvements. A full list of new RS5 features and instructions for getting started with flighting can be found here.
Fixed in this build
- We’ve fixed an issue preventing users from receiving incoming calls.
Known issues
- We are investigating lower than expected framerates and reliability issues when using remoting on this build.
If you have trouble booting your device while participating in the Insider program, you can find recovery instructions here. Please use the Feedback Hub to log any other bugs that you encounter while trying out this build as well as reaching out on the forums about questions.
Todd
This is now rolling out to all HoloLens users
This update severely broke all bluetooth input during unity application usage.
it will sometimes disconnect all devices.
Please fix!
I can no longer access the Device Portal over wifi consistently with this update. Also refusing my low latency MRC application.
Any chances this will get fixed in the next month?
You will need to log this problem on the Feedback Hub as documented here
I'm also having the bluetooth connectivity issue...do OS builds like 17763.167 come compatible with the Hololens? Can I use that version to fix? help!
