The Right Way to Export OLM files to Outlook
The outlook for Mac and MS Outlook are two different applications that are used by Mac users and Window users respectively. If an individual is shifted to Windows operating system then he/ she needs to migrate from Outlook for Mac to MS Outlook. This means conversion of OLM files to PST.
A free method to transfer files from OLM to PST is using IMAP Account
  • Create a Gmail account then make the following changes
  • Go to Gmail Settings and click on Forwarding IMAP/ POP tab
  • Make Gmail IMAP enabled and then go to Outlook for Mac
  • Add the Gmail account in Outlook for Mac
  • Select the files, folders to move and copy them to Gmail mailbox
  • When the transfer of files get complete, shift to MS Outlook
  • Go to MS Outlook and add same Gmail Account
  • As soon as the account is added the data will be automatically updated in MS Outlook
  • You can also refresh inbox and other folders by clicking on the send/ receive button
    The OLM files will be available in Gmail folder of MS Outlook.
  • Hi,
    If the manual method seems to be lengthy for converting OLM to PST then an alternate option is to use the third party tool. Because in a few steps the conversion process will get completed and novice user can easily use it.
  • To convert Mac OLM to PST file format using an excellent tool Mailvita OLM to PST Converter tool for Mac. This tool easy to converts all email items such as emails, notes, contacts, calendars, draft, tasks, journals, hyperlinks, email attachments etc. from .olm files and save in .pst format. It supports all versions of MS Outlook and all updated Mac OS versions.
  • edited January 2019
    OLM to PST Converter for Mac
  • To convert OLM to PST formats, there are lots of professional software available on the Web that can easily do this task. Kernel for OLM to PST Converter is such an effective software. This software can easily migrate emails, contacts, calendars, hyperlinks, email attachments of MAC outlook to MS Outlook PST formats. To know more about the software, visit: https://www.nucleustechnologies.com/blog/free-ways-to-convert-olm-to-pst-file/
  • Use this advanced tool OLM to PST Converter software that help you to export Mac Outlook to Windows Outlook PST format. It is simplest and easy to comprehend GUI that helps non-technical users to use and handle the software. It can easily convert OLM files to PST format with all details and attachments without losing any data.
  • OLM to PST conversion tool is the perfect tool to migrate Outlook Mac to Windows PST file format. This software split large PST to small PST file format. OLM to PST converter software can convert OLM file to PST, MBOX, MSG, EML, EMLX, HTML, etc.
  • michalemichale
    edited May 2019
    You may get various manual methods but they will not be helpful in the conversion of OLM database. That’s why many searches, I would like to recommend you Free OLM to PST Converter this tool for the quick and safe conversion of OLM files along with email files components.
    For more: https://www.mailvare.com/free-olm-to-pst-converter/
  • If the manual method does not work then you can go for any third-party tool to export OLM file to Windows Outlook. Here I would like to highly recommend you to use the best KDETools OLM to PST Converter tool which is a one-stop solution to migrate Mac OLM file to PST format. The tool imports the OLM file to Office 365 and a Live Exchange Server directly. It supports 25+ MBOX platforms like Apple Mail, Thunderbird, Spicebird Mail, etc.
    Get Free Download and install: http://www.olm-converter.com/
  • edited October 2019
    Get more effective highly advance software, you can use ToolsGround OLM to PST Converter Software. It can easy to convert all email items including email, attachment, contact, calendar etc. This software supports MS Outlook 2016/2013 (both 32 bit and 64 bit)/2010/2007/2003/2002/2000/98 and 97.
    More info:- toolsground. com/olm-to-pst-converter/
  • Convert Mac OLM data in PST format with MailsDaddy OLM to PST Converter tool and get a zero-loss resultant file with the same properties. It supports all Outlook versions and compatible with Windows OS (32-bit and 64-bit). Get the free OLM to PST Converter tool and perform a bulk migration without any data loss. Get complete information form the official website.
  • With this OLM to PST Converter tool anyone can easily Convert their Mac OLM file to PST file format in just few clicks.
  • Using one of the best DotStella OLM to PST Converter tools you can easily import multiple mailboxes from Mac OLM items to the PST file format for Outlook 2019, 2016, 2013, 2010.
    Try to free demo: https://www.dotstella.com/converter/olm-to-pst.html
    OLM Converter tool give you more benefits:
    • 100% safe conversion from OLM to PST
    • Save OLM in various file formats
    • Split Large Mac OLM into smaller PST by Size
    • There is no file size limit
    • Export OLM to Office 365, exchange servers directly
