How Do I import MBOX file to Outlook 2016
edited January 2019 in General
To get reliable solution to import MBOX to Outlook 2016, need to download Indya MBOX to PST Converter. The tool completely transfer mailbox data from MBOX to Outlook PST without losing or corrupting information.
Steps to Import MBOX to Outlook 2016
  • Download and setup the tool
  • Select .mbox file
  • Choose destination to save Output
  • Click convert
Access the resultant PST file from the desired path and directly import it into Outlook 2016.
Free Download the Tool: https://www.indyasoftware.com/dl/mbox-to-pst-converter.exe
    To import MBOX file to Outlook 2016, 2019 and below versions, you can use a third party tool like MBOX to PST Converter. Using this tool, users can also export MBOX to Office 365, Live Exchange server, EML, and MSG.
    Usually, several of us believe that converting MBOX file to PST files format is a very complex procedure, but such complications can be overcome by using MBOX to PST conversion tool
    Visit at ; https://www.spikevare.com/convert-mbox-pst-format/
    If there is any Mac user then this software will help him the MBOX to PST Converter for Mac software. This software flawlessly migrates all your MBOX files to Outlook PST format in only Mac OS without switching to Windows OS. It supports all version of Mac OS and doesn't need any further requirements.
    So, if you are planning to import MBOX to PST, then you will have to move MBOX files to PST format. For that, I can advise you to use MBOX to PST Export Tool, a feature-rich utility that will help you transfer MBOX mailboxes to PST file with all the data accurately saved. It also supports batch conversion option that allows converter of multiple MBOX files to PST at once, so converting your unlimited MBOX files to PST will not be a problem at all. Get an easy solution here:
    https://www.sametools.com/convert/mbox/
    This tool maintain the intigrity of data and the hierarchy of emails folders. MBOX to PST Software remain the same structure of MBOX data after conversion as it was before.
    Download this tool free trial version from here: http://www.mboxtopstconverter.emltopstutility.com/
    Importing of MBOX file to Outlook 2016 is easy and very simple.
    You can do this following these steps :
    1. Download Total Thunderbird Converter and Launch it.
    2. Select the folder filled with MBOX files in the folder tree.
    3. Select PST in the toolbar.
    4. START processing it.. thats it.
    You can start converting by downloading this software - https://www.coolutils.com/TotalThunderbirdConverter
    If you want to convert your MBOX file to Outlook then you can take help any professional tool like KDETools MBOX to PST Converter tool. This tool perfectly performs the migration of data from various email clients like Mac Mail, Thunderbird and Sea Monkey etc. It extracts all the essential email components like To, Bcc, Cc, Sent, From, Received, Attachments, etc. You can import your MBOX file to Outlook 2016 follow these steps:
    • Launch KDETools MBOX to PST Converter tool on your system.
    • Add the MBOX file that you want to import to Outlook 2016
    • Then you select the option to “Save to PST”.
    • Apply the required filters that you want.
    • Select a location on your system where you want to save the PST file.
    • Click “Next” to start the converting process.
    If you are looking best software of MBOX to PST Converter then try KDETools MBOX to PST conversion tool. By using this software you can easily convert MBOX emails to PST format. This tool supports all MBOX supportive email clients like Thunderbird, Apple Mail, Entourage, etc. It is capable to export PocoMail emails to PST including all attachments. Non-technical users can also use this software. It supports all MS Outlook versions 2019, 2016, 2013, 2010, 2007 & 2003
    Want to convert MBOX to PST file type? Get recommended solution that easily converts MBOX to PST format. It also helps you to convert MBOX file to Outlook data file.
    Visit: http://www.axblaze.com/products/mboxtopst-converter.html
    It's easy to import MBOX files to PST files using Mail Extractor Pro because the tool is the topper of the recommendation charts of both casual and professional users for a reason. The tool offers you the best of all these features combined into a one single package. It converts everything present in your input file plus also retains the folder hierarchy of the input file to make the output file a replica of the input file.Algorithm is inconsiderate of the encoding scheme of the data present in the input file. It converts all kinds of data present in the input file. Be it your nested messages or your calendar data etc., the tool converts them all.
    You can check it from here: https://www.uslsoftware.com/mbox-to-pst-converter-for-mac/
    Try SysCurve MBOX to PST Converter software and convert MBOX to PST file format. The software has a simple and modern UI. With this software, you can convert multiple MBOX files to Outlook PST format. The tool supports large size MBOX files.
    For more information, visit: http://www.syscurve.com/mbox-to-pst-converter.html
    If you want to import the MBOX file to Outlook 2016 then you don't need to go anywhere just download MailsDaddy MBOX to PST Converter. This simple and GUI based solution allows users to migrate MBOX file to Outlook from any MBOX, MBS, and MBX based email clients. It automatically preserves the mail properties, inline images, attachment, and folders in converted PST. The software has many other conversion formats such as PST, Office 365, EML, MSG HTML, etc.
    You can also download the free demo version here: https://www.mailsdaddy.com/mbox-to-pst-converter/
