How to Convert Outlook email (PST or Exchange) to MBOX format
Convert your Outlook email to Thunderbird MBOX file format by Using this Regain PST to MBOX Converter Software where you can easily convert your PST file into MBOX file in just few clicks. The software provides option to browse through this system and choose PST file whose emails you want to convert to MBOX. This feature comes handy for all the users who are well aware of the exact location of PST file in the PC. You can choose the current Outlook Profile to perform conversion.
Batch File Migration:-
Regain Outlook PST to MBOX converter is a complete tool which delivers best results with ease of use. It has batch system which helps you to export a lot of PST files in MBOX data at once. You should collect all PST files in one folder and choose the option “Add Folder” to add several PST files.
Get this Software free trial version from here: http://www.regainsoftware.com/pst-to-mbox-converter.html
  • To move Outlook PST file to MBOX file, you can also get the help of an Outlook PST repair software. The software can not only repair corrupt PST file, convert them into accessible MBOX formats. For more information, visit: https://www.datavare.com/software/pst-to-mbox-converter-expert.html
  • If you want to switch PST to MBOX format then you have to use third-party software like Outlook PST to MBOX format. Using this utility, you may change numerous PST files to MBOX format at once. The application maintains the folder structure, Rich text formatting, and Attachments after the conversion. For more detail visit website: https://www.sametools.com/convert/pst/
  • Mac user can go for a suitable PST to MBOX Converter for Mac this software helps the user to migrate Outlook PST files into MBOX format in Mac OS. Visit:- https://www.toolscrunch.com/mac-pst-to-mbox-converter.html
  • PST to MBOX Converter.For migrating PST file into MBOX format there is the one and only best method which is using third party tool. Many user now a days searching on internet with same queries that they all want to migrate their file in different format and the best tools comes out in this scenario is PST to MBOX Converter.
  • Outlook PST Recovery Tool is an exquisite tool that may repair even the maximum significantly broken PST record.It can without problems repair broken PST documents and connect Outlook mailbox quickly, this tool can get better all inaccessible PST document information which includes all objects from deleted emails and folders. The software program plays Outlook PST recovery by means of scanning your corrupt PST document and restoring all mail gadgets to a new PST. The recovery consists of each unmarried piece of records on your Outlook records file, consisting of emails, attachments, contacts, calendar items, journals, and notes. Allows saving recovered mails in MBOX, EML, MSG, RTF, HTML and so on codecs.
  • In today’s era, there are multiple email clients available which provide user to work with on any email client. So, the user may try the best tool i.e. Outlook Converter to export/convert Outlook PST file to PDF, MSG, EML, MBOX, NSF and etc. file format. It is the most suitable solution for users by which they can instantly access their Outlook mail to multiple file formats.
    **To more information:- ** https://cubexsoft.com/pst-to-mbox/
  • I would like to reply on this thread. There is lots of PST to MBOX Converter software present on the internet. But to select the best PST to MBOX converter is a very tough task. So here I recommend you one of the most effective software HowtoSol PST to MBOX Converter tool. This software also converts your all PST file to MBOX on different email clients like apple mail, Mozilla Thunderbird. This tool converts PST file to MBOX file in just a few clicks. It extracts all the essential email components like To, Bcc, Cc, Sent, From, Received, Attachments, etc. It also supports all versions of Windows and MS Outlook.
  • Jamie_9Jamie_9
    edited April 2019
    There is no direct method to convert Outlook PST file to MBOX file. You need to download KDETools PST to MBOX converter software. for converting PST file to MBOX which is a third party tool. The software allows convert PST to MBOX file in just a few simple clicks. It supports all MS Outlook versions.
  • Get easy way to convert Outlook PST to MBOX file type that can be easily imported in any MBOX supported platform.
    Visit: http://www.axblaze.com/products/psttombox-converter.html
  • Initially, you can try the manual method, which is not a direct method to export the Outlook data to MBOX format. However, if you find the manual method difficult. Then, SysTools Outlook PST to MBOX Converter is the ultimate relief for an effortless Outlook to MBOX Conversion, which is available for both Windows and Mac OS.
  • Hi,
    Whenever, user feels the requirement to export Outlook PST to MBOX format, then in that case users need to choose the most trustworthy tool. It is recommended to users to choose ZOOK PST to MBOX Converter.
    It is a 100% safe and secure solution for users to migrate Outlook emails to MBOX format. The tool makes all the task so simple & secure solution for users to transfer PST to MBOX format.
    Follow the simple steps: -
    • Download PST to MBOX Converter
    • Choose PST Files
    • Set Saving location.
    • Click on CONVERT button
    That's It!!!
    Download Source: - https://filehippo.com/download_zook-pst-to-mbox-converter/
  • PST to MBOX Converter is the reliable solution for you. I have used this software a month ago when my father was looking for quick conversion of PST to MBOX . You should also try this for your problems of PST to MBOX, MSG, EML, EMLX, and VCF
    You must try this tool:- https://www.toolsground.com/outlook-converter/
