How to Convert Offline Storage (OST) to PST (Personal Storage Folder) File?
If you Want to convert OST file to PST file then I would like to suggest you best tool Regain OST to PST converter on my well experience. With this tool user can smartly extract emails from OST file with all emails metadata- to, bcc, cc, date, time and subject etc as well as convert OST file into PST, EML, MSG and HTML formats. No technical skills Required to Operate this Software.
Support All MS Outlook Version:-
This tool support all the versions of MS Outlook. This tool has a very user friendly interface, anyone can access this application easily. You just use the free trial version of this application without hasitation.
You can try this tool free trial version from here: http://www.ostintopstconverter.com
    By using an OST to PST converter software like Kernel for OST to PST Converter, one can easily fix OST errors and move them into accessible PST formats. It also supports to recover deleted or inaccessible Outlook mailbox items. For more, visit: https://www.nucleustechnologies.com/blog/free-methods-convert-ost-to-pst-file/
    Outlook OST Mail Recovery from Shoviv is one another tool which provides a quick and safe solution to repair OST files and export OST to PST, Office 365, live Exchange server, EML, and MSG. Its simple user graphic interface makes it easy to use.
    I have used and located this OST to PST converter to be better than other OST to PST converter device in the marketplace. It's quickly recover ost file.
    I am using the software called as OST to PST Converter developed by Coolutils.
    This software has any features and easy to use.
    The converter is great for opening files stored on the Microsoft Exchange Server, transferring it on the local resources plus opening it on Outlook.
    The converter tool features a modest interface; thus it be can be launched from your desktop, trace destination path(s) in source OST files plus set those for the targeted PST files. You don't necessitate to surf for the OST files, as the program spots them automatically. Download it from official website - https://www.coolutils.com/OSTtoPSTConverter
    edited February 2019
    Take a proper utility to migrate OST in the MS Outlook PST. The OST to PST Migration Tool surely converts OST data to PST form with email elements like messages, attachments, notes, tasks, journals, metadata, etc. Also, software flawlessly works with MS Outlook 2000, XP, 2003, 2007, 2010, 2013 and 2016. To know more info here: https://www.sametools.com/convert/ost/
    Most of the people face OST corruption issue while exchange download. So, they need to transfer all database from OST file to PST file format. Now, using OST file exporter, you can convert OST file with emails properties without any damage or loss.
    Visit here more info: https://www.osttopstapp.com/
    There are many tools suggested to convert OST file to PST file type. As per my experience, I would like to suggest a solution which not only convert OST to PST but also makes you able to manage OST file data in a better way.
    Hi, I understand that you want to know how to convert OST file to PST file. you can convert OST file to PST file by using Microsoft OST to PST converter by KDETools. To convert OST file to PST format, open OST file in this software and select Save to PST option then click on Convert Now button. This Software also repair corrupted OST file and recover deleted OST file data. This software easily export all email items like emails, attachments, contacts, notes, calender and journals etc. This software has GUI interface & you don't need any technical skills, anyone can easily access this software. It works for all the versions of Microsoft Outlook & Windows.
    One of the best tool that i know and want to share is CoolUtils OST to PST Converter. It easily convert your OST file or files to PST. Unlike other tools, it works even if you do not have an Exchange Server connection. Recover Exchange mailbox folders by converting OST to PST and opening the converted PST file in Outlook.
    Follow link for details
    The OST to PST Converter developed by CoolUtils is the best solution for converting OST file to PST file. It will safely recover your all important files like tasks, contacts, emails, attachments, etc.
    This can easily convert or process large files with 100% accuracy.
    Read more - https://www.coolutils.com/OSTtoPSTConverter
    To convert Offline Storage OST file (.ost) in the PST format, you need to take the help from the 3rd party OST to the PST converter tool, because there is not free tool provided by Microsoft for converting orphaned OST file in the importable PST format. These tools are loaded with the so many great features link you could easily import the OST file data in the new Outlook profile, Office 365 & Exchange Server.
    Useful Resource, https://social.technet.microsoft.com/Forums/en-US/2cd7c789-1f05-4918-b41e-116b153bc319
