Holograms 240 not working
nash
I am having trouble getting Holograms 240 working. Everything works up to the point of sharing. After you go through that chapter you can no longer place the energy hub and the sharing service send an error back saying "XSocketManagerImpl.cpp (294): Received messge from {my device ip} with no assoicated socket"
"SessionMessageRouter.cpp (34)
nash ✭✭
The issue i had was trying to change the port number in Unity. The sharing service starts up and reports a different number than what gets loaded with the sharing prefab in unity.
Left the ports alone and everything worked fine.
@nash,
Are you running Holograms 240 on a device or in the emulator?
David
For this demo all clients should be primary.
Nash, did you start the service on your development machine, and put the IP of your development machine into the server address field of the sharing prefab? To start the service, select the 'HoloToolkit' menu option in Unity and then pick 'Launch Sharing Service'.
Also, be sure that there isn't a space before or after the IP address. If you press play in the editor you should see your local machine connect in the sharing service window.
