How to Convert an OST file to a PST file
Regain OST to PST Converter tool Easily convert OST data into Outlook PST data . This tool also recover corrupted OST data without and data loss. This program is intuitive and designed well. Even a non-technical user can handle this program. After exporting the whole data from OST to PST, you can get the file without any data loss. This program is intuitive and designed well. Even a non-technical user can handle this program. After exporting the whole data from OST to PST, you can get the file without any data loss.
Preview OST File:-
After scanning the ost file, this tool will show you all the convertible emails in preview itmes. Which you can check it by manual or by selecting a search option to search specific email. This helps you to make a decision, it is good for you or not ?
Get this tool free demo version from here: http://www.convertostintopstfile.com
  • I would also like to recommend another proficient and more advanced OST to PST converter software, which can easily fix OST errors and move them into accessible PST formats within few clicks. The software also allows you to recover deleted or inaccessible Outlook mailbox items. For more, visit: https://www.nucleustechnologies.com/blog/free-methods-convert-ost-to-pst-file/
  • Not to anxiety anymore, use OST to PST Tool an automatic software to save OST database in Outlook web app including complete data such as emails, contacts, calendars, notes, tasks, and attachments in as it is manner without any changes. Get more info here: https://www.gaintools.com/ost/pst/
  • Try one more solution named Shoviv for OST to PST Converter to accomplish your OST to PST conversion work. This tool has multiple wonderful features which help users to repair and export OST files into PST, EML, Office 365 and Live Exchange server. Read More: http://www.ostmailrecovery.com/
  • You can convert OST file to PST file format by using Microsoft OST to PST converter by KDETools. All you need to do is open OST file in this software & choose Save to PST option. Further, this tool supports conversion into multiple file formats (EML, MSG, HTML, EMLX, vCal, vCard, and MBOX) with all email properties. It has a free preview before converting OST file into PST file. It imports OST file to Office 365 & Live Exchange server. You can check & analyse this software on your own by using Free trial version of this software. You can convert 30 items from each folder for free.
  • Use the effective OST to PST Converter application that helps you to export single as well as multiple files in a few little moments. Before the conversion task, it displays the preview of recovered mailbox then store the data into multiple amazing file formats like PST, EML, EMLX, MSG, HTML, vCal, and vCard file formats. It is compatible to work with all the version of MS Outlook version 2019, 2016, 2013 and all below versions.
    Read more: http://ost4.com
  • I introduce Outlook OST file recovery software which is helpful to repair corrupted and damaged OST File and recover outlook OST file to PST file, MSG, HTML and many more format. Outlook OST to PST Software allow users to recover complete OST file or recover selective folders/ sub-folders from OST file and restore OST with emails, contacts, notes, task, journals and appointments. The software successfully processes and recover emails from every version of OST file including OST 2016, 2013, 2010, 2007 to 97 (32 and 64 Bit).You make the OST Recovery and conversion without needing MS Outlook or any other software. OST to PST Recovery software works independently and extract each and every OST items into various file extension like PST, EML, EMLX, MSG, HTML and vCard file. https://www.osttopstapp.com/ost-recovery.html
  • Hi, If you want to convert OST file to PST file format then I found an informative article for you. Where I have explained the best possible methods to perform this task. https://www.dataforensics.org/two-freeware-solutions-to-convert-ost-to-pst-file/
  • OST to PST Converter software provides the best solution to convert your OST file without any intervention. This software safely converts all mail items of Offline folder (OST) file and saves them in new Outlook PST files, along with giving the option to save as EML, MSG, and MBOX formats. You can test the software on any version of MS Windows operating system for any version of MS Outlook and MS Exchange server as it is compatible with the entire range of versions of all of them.
    Read More Info, Visit Here:- https://www.toolsbaer.com/ost-to-pst-conversion/
